Hyduralic Throw-Out Bearing |
pjhaun |
Aug 11 2007, 09:27 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Has anybody ever heard of a hyduralic throw-out bearing and if there is any for the 901 transmission?
Thank You!!!! Phillip J. Haun Oak Harbor, WA. |
Dr Evil |
Aug 11 2007, 11:57 PM
Sure. You could find one that fits your dimensions fairly easily, they are not uncommon and I bet there is an after market set. Then you will have to figure out how you are going to do the pedal cluster with another MC for the clutch. I am sure someone here has done it before.
So.Cal.914 |
Aug 12 2007, 08:08 AM
The one I saw pics of was the guy down under, (:insert the OH $HIT I can't remember his name smilie:) He posted some good pics of his setup(No I can't post those pics, not at home) right around the time of the last big
discussion about brakes. |
Aaron Cox |
Aug 12 2007, 03:44 PM
wevo makes them for 915 and 930 applications iirc....
worth a look (IMG:style_emoticons/default/smile.gif) wouldnt it be easier to hook up a slave cylinder instead? Hyd. TO bearing dies and you have to pull the tranny.... slave dies and you unbolt it. |
JPB |
Aug 12 2007, 06:49 PM
You can get some cool after market stuff like CNC hydraulic clutch kits which include a clutch pedal with a reservoir and an external slave cylinder. The last one I saw was on a Becks 550 replica. They beafed up the location where the stock cable went through where the slave was bolted but that was on a VW trany. I think you would need to fab a beafy clip that bolts to your trany. As mentioned above, keeping everything external keeps it symple. (IMG:style_emoticons/default/beer.gif)
Dr Evil |
Aug 12 2007, 08:32 PM
wevo makes them for 915 and 930 applications iirc.... worth a look (IMG:style_emoticons/default/smile.gif) wouldnt it be easier to hook up a slave cylinder instead? Hyd. TO bearing dies and you have to pull the tranny.... slave dies and you unbolt it. I agree, good idea. (IMG:style_emoticons/default/agree.gif) |
Cap'n Krusty |
Aug 12 2007, 09:07 PM
90s Jeeps had 'em, and they were a weak point. The Cap'n
sixnotfour |
Aug 12 2007, 09:55 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE 90s Jeeps had 'em, and they were a weak point. The Cap'n Funny you mention that , I had a brand new 1990 Jeep Wrangler, under 2k miles it started to leak, Chrysler would not fix it as it was clutch related.SOB's. QUOTE wouldnt it be easier to hook up a slave cylinder instead? Good Thinking |
Twystd1 |
Aug 12 2007, 10:17 PM
"Tilton" makes the Hydro T/O bearing you are discussing.
Clayton |
Downunderman |
Aug 13 2007, 03:08 AM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
Will post the photos tomorrow morning. They are on the computer at home. That wont be long because i'm 3/4 of a day in front of you.
Mikey914 |
Aug 13 2007, 03:33 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My 944T has a a hydrolic clutch
RON S. |
Aug 13 2007, 05:54 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I did mine with a hydraulic clutch several years back. I grafted a 964 master cylinder onto my pedal cluster,and used a Wilwood slave cyl.on the trans end. The pics are several years old,so everything has been tightened up to work properly. Ron Attached image(s) |
degreeoff |
Aug 13 2007, 07:23 AM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
KISS (keep it simple stupid)
just my $.02..... |
Brando |
Aug 13 2007, 09:45 AM
944 master cylinder, second reservoir, 944 slave cylinder. Inexpensive and will work good. Just need to do a little fabrication on the transmission end for a bracket that holds the slave cylinder in place to activate the throwout bearing.
Cap'n Krusty |
Aug 13 2007, 10:05 AM
Downunderman |
Aug 13 2007, 02:43 PM
This is the Tilton one:
http://www.tiltonracing.com/content.php?page=hydraulic However, as i'm using a 911 pull clutch I could do it externally. Attached image(s) |
Cap'n Krusty |
Aug 13 2007, 03:15 PM
You're STILL missing the point ..................... Take a look at this:
http://www.novak-adapt.com/images/pics/jee...out_bearing.jpg The Cap'n |
Brando |
Aug 13 2007, 11:16 PM
Why would someone want that? Super-pain-in-the-ass when it fails. (Not IF but when).
Mikey914 |
Aug 13 2007, 11:27 PM
I understood the throwout bearing question. I was pointing out that the 944 has a system that may be adapted without using a hydrolic throw out bearing.
drive-ability |
Aug 13 2007, 11:30 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
Why would someone want that? Super-pain-in-the-ass when it fails. (Not IF but when). I agree if it fails your in for more work and expense to replace it, but as I see it there are less moving parts, less bearing races to wear etc. I have a 930 transmission and there is a lot of things leading up to releasing the clutch disk. I would go that way and may but it would have to be correctly machined and good quality. With a big pressure plate there is a ton of pressure placed on the factory parts as well as alignment issues that are critical when using a heavy PP. I don't disagree if you have something working, why change it? |
Lo-Fi Version | Time is now: 16th May 2024 - 02:28 AM |
