| John |
Aug 14 2007, 01:08 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Any advice/suggestions for mounting a video camera in our track only car? There is virtually no interior left and a bracket would be fabricated and welded into place for mounting.
Any brand/model recommendations? Any brands/models to avoid? The car is a DE only vehicle. What I THINK I want is a small, lightweight camera that stores video on Digital Tape, and can be powered from the car 12v system. I want something that will be easy to transfer video to a PC and then burn DVD's to be played in stand-alone players. I want enough resolution that it will look decent full screen on a television. It will need to be hard wired as there is no lighter plug (or dash for that matter). Thanks in advance for your replies. |
John Video Camera Questions Aug 14 2007, 01:08 AM
Brando Why not one of those compact sony DV recorders? I... Aug 14 2007, 11:11 PM
John
Why not one of those compact sony DV recorders? I... Aug 14 2007, 11:53 PM
blitZ One of the cart guys at my local SCCA group has a ... Aug 15 2007, 07:58 AM
Joe Ricard Something to consider when mounting is EMI shieldi... Aug 15 2007, 10:14 AM
John
Something to consider when mounting is EMI shield... Aug 15 2007, 10:23 AM
john rogers I have been using a setup called Race Cam for seve... Aug 15 2007, 12:24 PM
Dominic L I have the io port mount and only tried it with th... Aug 16 2007, 05:56 PM
turboman808
I have the io port mount and only tried it with t... Sep 3 2007, 11:19 PM
drew365 I was going to suggest the Pelican thread that Don... Aug 17 2007, 10:02 AM
john rogers I would be surprised if there was much EMI or elec... Aug 17 2007, 11:20 AM
John
Several things to consider if getting a hand hel... Aug 17 2007, 11:25 AM
Dominic L
I would be surprised if there was much EMI or ele... Aug 17 2007, 05:51 PM
mikelsr Several things to consider if getting a hand held ... Sep 3 2007, 05:30 PM
john rogers I have a UV filter on the camera mostly as a prote... Aug 17 2007, 10:17 PM
John I've been playing around with my wife's DC... Sep 4 2007, 12:16 AM
turboman808
Here is a question about the videos posted on the... Sep 4 2007, 01:59 AM
Dominic L
Here is a question about the videos posted on th... Sep 4 2007, 07:17 PM
turboman808
Thanks for the tips, Nathan. I went ahead and bou... Sep 4 2007, 08:25 PM
Dominic L
I use Sony Vegas. Way before I picked up a came... Sep 6 2007, 05:38 PM
byndbad914
Thanks for the tips, Nathan. I went ahead and bo... Sep 6 2007, 08:24 PM
turboman808
so in other words.... we all know who to send raw... Sep 11 2007, 06:21 PM
John Ok,
I have done my first experimentation at recor... Oct 22 2007, 11:55 AM
ConeDodger I use an I/O Port mount that attaches to my harnes... Oct 22 2007, 01:34 PM
John Here is a link to my first attempt:
3 laps at He... Oct 24 2007, 12:14 AM
Racer Chris That looks good John.
Your camera mount appears to... Oct 24 2007, 05:07 PM
John
Your camera mount appears t... Oct 24 2007, 10:23 PM
Racer Chris
Are you referring to the vibrations? The mount i... Oct 26 2007, 01:05 PM
John
The vibrations are something I expect. The flex... Oct 26 2007, 02:11 PM
Dominic L
It did suffer from compression, but it does work.... Oct 25 2007, 08:58 PM
John
It did suffer from compression, but it does work... Oct 27 2007, 02:08 PM
John Thanks for the tip. I'll go read that.
In th... Oct 25 2007, 09:20 PM
wobbletop
In t... Oct 25 2007, 10:37 PM
John
Was that a throttle lift spin?
I'm new to ... Oct 26 2007, 02:34 AM
John Watch as the Chevron goes past!
That thing w... Oct 26 2007, 08:10 PM
TimT All the videos posted on my site were made using a... Oct 29 2007, 09:33 PM
John WOW Tim,
That was fun.
It was good to see Summit... Oct 29 2007, 10:25 PM
TimT OK I just checked what kind of camera I do have, S... Oct 30 2007, 12:31 AM
John
Im wondering if alot of what is percieved as came... Oct 30 2007, 08:22 AM
turboman808 I got to film with Chris one day a few months ago.... Nov 27 2007, 03:30 PM
John The high resolution isn't the problem that I... Nov 27 2007, 03:44 PM
wobbletop
The high resolution isn't the problem that I... Nov 27 2007, 04:04 PM
John
The high resolution isn't the problem that I... Nov 27 2007, 08:30 PM
wobbletop Your posted videos look good considering the crap ... Nov 27 2007, 09:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:31 AM |
