> Video Camera Questions, considering installing an in-car cam
John
post Aug 14 2007, 01:08 AM
Post #41
member? what's a member?
Any advice/suggestions for mounting a video camera in our track only car? There is virtually no interior left and a bracket would be fabricated and welded into place for mounting.
Any brand/model recommendations? Any brands/models to avoid?
The car is a DE only vehicle.
What I THINK I want is a small, lightweight camera that stores video on Digital Tape, and can be powered from the car 12v system. I want something that will be easy to transfer video to a PC and then burn DVD's to be played in stand-alone players.
I want enough resolution that it will look decent full screen on a television.
It will need to be hard wired as there is no lighter plug (or dash for that matter).
Thanks in advance for your replies.
John   Video Camera Questions   Aug 14 2007, 01:08 AM
Brando   Why not one of those compact sony DV recorders? I...   Aug 14 2007, 11:11 PM
John   Why not one of those compact sony DV recorders? I...   Aug 14 2007, 11:53 PM
blitZ   One of the cart guys at my local SCCA group has a ...   Aug 15 2007, 07:58 AM
Joe Ricard   Something to consider when mounting is EMI shieldi...   Aug 15 2007, 10:14 AM
John   Something to consider when mounting is EMI shield...   Aug 15 2007, 10:23 AM
john rogers   I have been using a setup called Race Cam for seve...   Aug 15 2007, 12:24 PM
Dominic L   I have the io port mount and only tried it with th...   Aug 16 2007, 05:56 PM
turboman808   I have the io port mount and only tried it with t...   Sep 3 2007, 11:19 PM
drew365   I was going to suggest the Pelican thread that Don...   Aug 17 2007, 10:02 AM
john rogers   I would be surprised if there was much EMI or elec...   Aug 17 2007, 11:20 AM
John   Several things to consider if getting a hand hel...   Aug 17 2007, 11:25 AM
Dominic L   I would be surprised if there was much EMI or ele...   Aug 17 2007, 05:51 PM
mikelsr   Several things to consider if getting a hand held ...   Sep 3 2007, 05:30 PM
john rogers   I have a UV filter on the camera mostly as a prote...   Aug 17 2007, 10:17 PM
John   I've been playing around with my wife's DC...   Sep 4 2007, 12:16 AM
turboman808   Here is a question about the videos posted on the...   Sep 4 2007, 01:59 AM
Dominic L   Here is a question about the videos posted on th...   Sep 4 2007, 07:17 PM
turboman808   Thanks for the tips, Nathan. I went ahead and bou...   Sep 4 2007, 08:25 PM
Dominic L   I use Sony Vegas. Way before I picked up a came...   Sep 6 2007, 05:38 PM
byndbad914   Thanks for the tips, Nathan. I went ahead and bo...   Sep 6 2007, 08:24 PM
turboman808   so in other words.... we all know who to send raw...   Sep 11 2007, 06:21 PM
John   Ok, I have done my first experimentation at recor...   Oct 22 2007, 11:55 AM
ConeDodger   I use an I/O Port mount that attaches to my harnes...   Oct 22 2007, 01:34 PM
John   Here is a link to my first attempt: 3 laps at He...   Oct 24 2007, 12:14 AM
Racer Chris   That looks good John. Your camera mount appears to...   Oct 24 2007, 05:07 PM
John   That looks good John. Your camera mount appears t...   Oct 24 2007, 10:23 PM
Racer Chris   Are you referring to the vibrations? The mount i...   Oct 26 2007, 01:05 PM
John   The vibrations are something I expect. The flex...   Oct 26 2007, 02:11 PM
Dominic L   It did suffer from compression, but it does work....   Oct 25 2007, 08:58 PM
John   It did suffer from compression, but it does work...   Oct 27 2007, 02:08 PM
John   Thanks for the tip. I'll go read that. In th...   Oct 25 2007, 09:20 PM
wobbletop   Thanks for the tip. I'll go read that. In t...   Oct 25 2007, 10:37 PM
John   Was that a throttle lift spin? I'm new to ...   Oct 26 2007, 02:34 AM
John   Watch as the Chevron goes past! That thing w...   Oct 26 2007, 08:10 PM
TimT   All the videos posted on my site were made using a...   Oct 29 2007, 09:33 PM
John   WOW Tim, That was fun. It was good to see Summit...   Oct 29 2007, 10:25 PM
TimT   OK I just checked what kind of camera I do have, S...   Oct 30 2007, 12:31 AM
John   Im wondering if alot of what is percieved as came...   Oct 30 2007, 08:22 AM
turboman808   I got to film with Chris one day a few months ago....   Nov 27 2007, 03:30 PM
John   The high resolution isn't the problem that I...   Nov 27 2007, 03:44 PM
wobbletop   The high resolution isn't the problem that I...   Nov 27 2007, 04:04 PM
John   The high resolution isn't the problem that I...   Nov 27 2007, 08:30 PM
wobbletop   Your posted videos look good considering the crap ...   Nov 27 2007, 09:43 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:34 AM
