vw bus 1.8 vs. 914 1.8, what the difference ? or how are they different |
hedgehog |
Aug 22 2007, 02:18 PM
Member Group: Members Posts: 50 Joined: 6-June 06 From: Central Calif Member No.: 6,169 Region Association: Central California |
an ad in the local paper said 75.00 or best offer...was wondering if it is interchangable with a 914 motor and/or if it is worth it....
Cap'n Krusty |
Aug 22 2007, 02:32 PM
The '74 1.8 was carbureted, the '75s were either FI or carbureted, depending on the market. Lower compression, FI system is similar but different, carbs are a nightmare. Dipstick tube is missing on the VW bus cases. Carb engines have air pump fittings on the heads. Flywheel is cut differently. That said, a good case is worth the money, if you need one.
The Cap'n |
SLITS |
Aug 22 2007, 02:38 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
1.) Dipstick location will be a long tube bolted to the boss on the bottom of all the cases rather than in the top location of a 914. Boss can be blocked off with a plate and the dipstick relocated to the 914 style.
2.) '74 was carburetored ... Case Code AW .... Heads 021 101 371 H or S ... they would have 3 EGR holes .. two in one head, one in the other. Valve size In 41mm / Ex 34mm 3.) '75 went L-Jet injection ...Case Code AW ... EGR holes eliminated / CHT added ... Valve size reduced In 39.3mm / Ex 34 mm .... same part numbers 4.) All 914 heads had sodium filled exhaust valves ... Type 2 didn't. 5.) Type 2 bus engines, as far as I remember, had a much deeper dish in the piston for lower compression ratio. Think thats about it ........ Ya beat me to it Krusty One |
Twystd1 |
Aug 22 2007, 09:27 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
I am going by memory here. Crusty will tell us if I am right.
But I believe the Bus/Vanagon Exhaust ports are different (square) if they were made after 1978. Those don't flow like a teener head. Clayton |
euro911 |
Aug 22 2007, 10:09 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
LvSteveH |
Aug 22 2007, 10:38 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
I had a similar motor in a 914 and it was great on hills, but off the line, it was a dog. I actually got out accelerated by a diesel truck pulling a large 5th wheel. The sad part was he probably wasn't even trying.
Don't get me wrong, it was a fun setup, and great for traveling. Around 30mpg and at 3200 rpm's it would hold 75 through the mountains without any trouble at all. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:58 PM |
