| PeeGreen 914 |
Nov 20 2007, 12:24 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
So does that mean we get to hear results very soon (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/cheer.gif)
| iamchappy |
Nov 20 2007, 02:28 PM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Well the engine guys think they may have done something wrong with the orientation of the twinplug dizzy and they didn't like the leak down on number 1 when they were trying to get it at tdc..
I left the car with them so they can figure it out. I am still waiting..... |
| PeeGreen 914 |
Nov 20 2007, 02:41 PM
(IMG:style_emoticons/default/chair.gif) I am sure that is disheartening. Well, I hope they figure it out quickly.
| lotus_65 |
Nov 20 2007, 04:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
shows how wise you where to have them fire it up.
good call, they'll get it right. |
| rick 918-S |
Nov 20 2007, 06:40 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,192 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I'm pacing here... I can't even imagine how your feeling.
| John |
Nov 20 2007, 07:56 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
What kind of power is expected from this engine?
| iamchappy |
Nov 20 2007, 09:06 PM
Im not worried, for one the engine has sat for over a year after it was put together, When priming the injectors the fuel must of washed any oil left in the cylinders from installing the pistons away. The cold start washed even more on cranking to start it today and the rings haven't been sealed yet. The plugs they pulled were wet.
The shop is going to pull the rest of the plugs and squirt some oil in, crank it over and pump up the oil pressure with the fuel pump disconnected, and check the leak down, I think they are wasting there time, i believe everything is ok, but am grateful their wish is to make sure it is. I have waited this long might as well make sure everything is right. My big worry is the weather, so far no snow but I am biding my time on that, I want to get some miles on the car before that shit happens.... I can se it now, Ollie and I sitting in the garage in the car drinking a beer listening to the stereo and pretending were driving, while there is 2ft of snow out the door and it's still falling. Answer to power, around 420hp is expected in relation to other engines with similar builds.. |
| WaideS |
Nov 28 2007, 11:07 AM
Has been ![]() ![]() Group: Members Posts: 220 Joined: 25-January 06 From: Valley of the Sun Member No.: 5,475 Region Association: None |
| rick 918-S |
Nov 28 2007, 11:28 AM
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/huh.gif) We need a pacing smiley... (IMG:style_emoticons/default/smile.gif)
| iamchappy |
Nov 28 2007, 02:14 PM
I give up they said today but I am still waiting. They must be holding out for the snow.
Spent the day working on the rockers and valance the garage is a mess good thing the car isn't here. |
| aircooledboy |
Nov 29 2007, 12:01 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Doing my best imitation of my 12 year old's whiney impatient voice:
Ohhhh come onnnnnnnnn!!!!!! (IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/monkeydance.gif) |
| iamchappy |
Nov 29 2007, 01:38 PM
These guys are trying to figure out why 1 and 3 have bad leak down numbers, if i have to I will drop the motor and have them recheck there work.
I really cant understand nor can they, why the leak down numbers are bad as I am sure they checked them when they built the engine and the things not been started yet. |
| lotus_65 |
Nov 29 2007, 02:30 PM
These guys are trying to figure out why 1 and 3 have bad leak down numbers, if i have to I will drop the motor and have them recheck there work. I really cant understand nor can they, why the leak down numbers are bad as I am sure they checked them when they built the engine and the things not been started yet. (IMG:style_emoticons/default/dry.gif) that's (IMG:style_emoticons/default/stromberg.gif) |
| iamchappy |
Nov 29 2007, 08:59 PM
They started it today and said the engine sounded great. Tomorrow we will re-start again and time it. I did notice some oil leakage from the base of the cylinder and case on the bad leak down cylinder #1. I have to decide weather to break-in the engine and hope everything seals up. When I have to re-adjust the valves, re-check the leak downs and if bad tear it down and fix, or tear it down if the leak down numbers dont improve in #1 and #3 after tomorrow. I think (but I really dont know for sure) that the rings and cylinders really need to seal during break-in for good leak down numbers. The shop thinks everything should seal up but seemed a little worried about it yesterday.
| PeeGreen 914 |
Nov 29 2007, 09:10 PM
Well, I hope everything goes well. Are you sure everything was torqued to spec? I have heard of people building engines and forgetting to toque the heads properly.
| rick 918-S |
Nov 29 2007, 09:39 PM
Run it for a day and see how things shake down then have them fix the oil leak at least. You would think if the leak down numbers are off the crank case pressure would increase and that oil leak will get worse.
| iamchappy |
Nov 29 2007, 09:40 PM
All torqued correctly using Supertec Head studs. Over on the Bird board they think everything will seal up also.
| rick 918-S |
Nov 29 2007, 09:57 PM
Chappy, My engine should be back in this weekend. Too bad It's supposed to snow like hell here Saturday. (IMG:style_emoticons/default/dry.gif) I would be all over a road trip!
| iamchappy |
Nov 30 2007, 06:36 AM
The 914 Gods are doing this to us, we must of been naughty, or the cars are scared to death.
| lotus_65 |
Nov 30 2007, 07:50 AM
Lo-Fi Version | Time is now: 6th February 2026 - 02:03 PM |
