Rear Swaybar bent |
Rear Swaybar bent |
brer |
Aug 24 2007, 12:31 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
installed my rear sway, and the thing must have been on a car that did nothing but right hand turns as it appears to be bent higher on one side than the other.
can ya shim the mounts to correct this? I'm also thinking of an adjustable link, but its pretty far off as it is. maybe both... anyone done this one? BTW- Weltmeister sway bushings are sooooo squeeky, yuk. |
dr914@autoatlanta.com |
Aug 24 2007, 12:48 PM
914 Guru Group: Members Posts: 7,842 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
installed my rear sway, and the thing must have been on a car that did nothing but right hand turns as it appears to be bent higher on one side than the other. can ya shim the mounts to correct this? I'm also thinking of an adjustable link, but its pretty far off as it is. maybe both... anyone done this one? BTW- Weltmeister sway bushings are sooooo squeeky, yuk. I would remove it and bend it. |
Twystd1 |
Aug 24 2007, 03:29 PM
Did it bend AFTER you installed it..???????
If so..... You have a bind that NEEDS to be taken care of before you do anything else. I might be down your way tomorrow on Biz.... Ya wanna hook up and see what we can do..??? Cheers, Clayton |
brer |
Aug 24 2007, 10:06 PM
hell yes.
i'll pm you. |
SLITS |
Aug 25 2007, 07:04 AM
Did it bend AFTER you installed it..??????? If so..... You have a bind that NEEDS to be taken care of before you do anything else. I might be down your way tomorrow on Biz.... Ya wanna hook up and see what we can do..??? Cheers, Clayton Oh the agony ...... if Claytonian The First hands' touch it ... it will never run again. (IMG:style_emoticons/default/chair.gif) |
So.Cal.914 |
Aug 25 2007, 07:41 AM
Oh the agony ...... if Claytonian The First hands' touch it ... it will never run again. (IMG:style_emoticons/default/chair.gif) Now hold on Ron, if it were yours wouldn't you want someone that had something in common with your cars problem working on it? Seams to me that Clayton is a little "bent" too. (IMG:style_emoticons/default/biggrin.gif) |
brer |
Aug 25 2007, 10:00 PM
fixed!
took out the weltmeister and reinstalled the soft, slightly worn stock bushings and it moves freely again, no squeeking, and both ends of the bar are level. It seems that my mounts are ever so slightly out of alignment, not a problem with soft stock bushings, but the hard weltmeisters with no give created a bind and tweek on my bar. They tweeked on my bar. (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 05:28 AM |
