> What can I do with a 1.7
quadracerx
post Aug 25 2007, 01:12 PM
I have a 73 1.7 motor...whats the biggest bore you can do...with and without machine work(how big will that make the more?)....
IF I decide to do machine work what exactly needs to be done?
Can you suggest a machinist in the Seattle area that is qualified to do this work?
Thanks....
Steve
post Aug 25 2007, 01:33 PM
Resident German
QUOTE(quadracerx @ Aug 25 2007, 11:12 AM) *
the easiest upgrade would be a set of 96mm pistons & cylinders.
that'll give you 1911cc
add one of Jake's Cams and a set of dual 40 IDF weber carbs and you have one peppy little 1.7L ...
(IMG:style_emoticons/default/bye1.gif) Andy
orange914
post Aug 25 2007, 05:23 PM
http://5starmediaworks.com/index.html
QUOTE(SirAndy @ Aug 25 2007, 12:33 PM) *
you'll have to open the head to cylinder mating surface up- or - go with 1.8 or 2.0 heads. if you go with the 914 (non bus heads) you'll also have to change/ modifiey the 2 spark plug tins. (IMG:style_emoticons/default/thumb3d.gif)
mike
post Aug 25 2007, 06:36 PM
Resident German
QUOTE(orange914 @ Aug 25 2007, 03:23 PM) *
yes. i thought that was obvious when increasing bore, but thanks for pointing it out ...
(IMG:style_emoticons/default/shades.gif) Andy
Twystd1
post Aug 25 2007, 07:08 PM
You don't want to know... really.....
This could get into a real lengthy conversation that has been played out here MANY times.
So I have a question for you that will help you get to your result in the best way possible.
Question: How much money are you allocating for ALL of your engine performance mods?
The answer to that question will help US to help YOU.
You could easily put out 15 - 20K + for the best of the best. Or you could do a basic performance rebuild for around 1500 bucks including carbs using deals from the fellas here and searching for the best used performance deals/parts possible.
It's all about the Benjamins VS performance.
Name your price.......
Regards,
Clayton
So.Cal.914
post Aug 26 2007, 08:28 AM
"...And it has a front trunk too."
You could get a good used 2.0 crank and rods, 96's for a 2.0, cut your heads for
the 96's, a cam from jake and a set of 40's (webers (IMG:style_emoticons/default/smile.gif) ) from the classifieds. You'll
end up with a 2056cc. 2.0 heads would be better but if money is tight the 1.7's will
do, and no mods. Have fun.
- Lo-Fi Version Time is now: 4th November 2026 - 10:26 AM
