> Oil for 914
partwerks
post Aug 25 2007, 09:01 PM
Has anyone ever heard of Lucas oils or had any experience with it & if so, would it be a good oil to run in a 914 as a truck driver told me that all truck drivers he knew run it in the differential because it dramatically lowered the temperature.
Allan
post Aug 25 2007, 09:05 PM
Teenerless Weenie
Any 20-50 oil will work fine as long as you change it every 3000 miles....
Twystd1
post Aug 25 2007, 09:41 PM
You don't want to know... really.....
Read this...
Air cooled Oil info.
This is specific to air cooled engines. Jake and Charles have done a bunch of homework on this topic. it is worth a read.
Clayton
Borderline
post Aug 25 2007, 11:19 PM
and this:
Castrol GTX broke down in 800 miles!
I've always kinda took oil for granted....not any more!
craig downs
post Aug 26 2007, 01:25 AM
Especially after the resent new low emission formulations. Using these oils in a engine
with solid lifters is like pouring in liquid death. These engines need the right amount
of zinc which the new formulations have removed. You owe it to yourself and read
the report that Charles and Jake did on oils.
toon1
post Aug 26 2007, 01:42 AM
royal purple or Bradd penn
BarberDave
post Aug 26 2007, 04:41 AM
Barberdave
I presently run Royal Purple,I will switch to Brad Penn at my next oil change. Jake's and Charles info on the zink thing,( or lack of it) is enought for me. After all who does more research on air cooled motor's than these two guy's. my 2 cents Dave (IMG:style_emoticons/default/slap.gif)
jwhcars
post Aug 26 2007, 05:58 AM
I am using Valvoline racing oil contains added zinc and friction modifiers. I don't need to worry about the catalytic converter-antique tag = no state inspection needed.
- Lo-Fi Version Time is now: 1st May 2026 - 03:01 AM
