If you had a weber progressive, would you buy these?, 'professionally rebuilt' weber 40IDF's |
purple |
Aug 27 2007, 10:37 AM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
Well guys...It looks like this gentleman, from this forum, has a pair of hotness weber 40 IDF's rebuilt...what do you guys think?
What's involved with putting these on? http://www.914world.com/bbs2/index.php?showtopic=75459 Is the price good? I can get a whole new set for ~800 with linkages and full gaskets |
BarberDave |
Aug 27 2007, 11:14 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I have 40IDF on my 914 ,love them. Oh of course i went from the Boat Anchor weber progressive also. What a difference,wow, there was a stop along the way with 34 ICT's ,two small. Price on the 40's is fair,not a smokeing deal,but fair. New is new, $250.00 difference ,does that buy piece of mind or guarantee I don't know. Me i would go with the new. Did I when I got mine NO,wish I did ,I spent time and money to dial them in ,jet wise. My 2 cent,s probbly not worth that! (IMG:style_emoticons/default/slap.gif) Dave |
purple |
Aug 27 2007, 11:39 AM
Do the 40's from 9motorsport come jetted for 914's?
i would personally like the peace of mind of new from 9motorsport |
type11969 |
Aug 27 2007, 11:45 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
For 950, if you buy from aircooled.net, you get your carbs setup for free and I believe you can keep on swapping out jets for free to dial them in perfect for your engine (they used to do that, not sure if they still do):
http://www.aircooled.net/new-bin/viewprodu...020&cartid= |
purple |
Aug 27 2007, 11:55 AM
Damn, that's badass!
I bet I'd spend more in jets and shipping to get the right ones after getting the kit from somewhere else. And I know Jake knows what he's doing with these. Now, about coming up with 1 M note.... |
sww914 |
Aug 27 2007, 12:13 PM
After I got my 44's, I made 1 call to Fat Performance in So Cal. I explained to them what I already had in my carbs, what size cam, valves, pistons, compression, etc., and they sent me a set of jets with an optional set of idle jets to try. It runs perfect!
Unbelievably good! There's nothing like blasting past well prepared 911's on the straightaway in a 914-4! Fat performance has been building racing T-4 engines for as long as some T-4 engine builders have been alive. |
So.Cal.914 |
Aug 27 2007, 12:17 PM
Well guys...It looks like this gentleman, from this forum, has a pair of hotness weber 40 IDF's rebuilt...what do you guys think? What's involved with putting these on? http://www.914world.com/bbs2/index.php?showtopic=75459 Is the price good? I can get a whole new set for ~800 with linkages and full gaskets Make an offer, If I remember correctly webers are not made in Italy any longer. They come with everything, and everything costs money. These appear to be rebuilt. Up to you but I have been useing and rebuilding mine sense 82 and they still rebuild and work well. |
type11969 |
Aug 27 2007, 02:18 PM
Thats not Jake's website (dunno if he offers a similar deal though), it is John Connelly's (sp) who has been on the VW scene for a long time. Definitely knows what he is doing . . .
Damn, that's badass! I bet I'd spend more in jets and shipping to get the right ones after getting the kit from somewhere else. And I know Jake knows what he's doing with these. Now, about coming up with 1 M note.... |
purple |
Aug 27 2007, 02:39 PM
My problem is that i have NO idea what's in my engine. It may even be a bus engine as it's got hydro lifters. So I guess jetting would be some exercise in turd polishing?
type11969 |
Aug 27 2007, 03:31 PM
Well with the engine and head serial numbers you should be able to get an idea of the displacement, the valve sizes, and the source of the engine . . . that should be all you need to get close enough. Hydro lifter engine isn't going to spin much past 5k, my guess is the valves are pretty small (actually I think the hydro engines only came with one valve size), so with that you can make a good guess about vent size, mains are based off vents and max rpm, idles and airs you can just start at a generally accepted value and go from there.
Reference for serial numbers: http://www.tunacan.net/t4/reference/index.html |
type11969 |
Oh, and if you got a wide band O2 sensor then you could really get it dialed in just right.
Joe Ricard |
Aug 27 2007, 04:01 PM
Even if you stumble blind drunk and dumb getting the right for one variable like hot humid. You will need different jets for cold dry.
The carbs in the original link are older style. nothing wrong with them just different acceleration linkage. |
Twystd1 |
Aug 27 2007, 04:57 PM
There has been A LOT of bad press on the new Webers.
Yet I have a tendancy to tryst ANYTHING John Connely sells at Aircooled.net. He is a very good guy and very knowledgeable. Go check out Cal look or the Samba forums... They bag on the NEW webers pretty badly.. (as of 6 months ago) Maybe something has changed. ME... I would just rebuild an old set. Cause I have done so many over the years. I know what to look for. And I can usually get em for a bout 400 a set. Thats my experience. Yours may be different. Cheers, Clayton |
Twystd1 |
OOOps..... Double post
purple |
Aug 27 2007, 09:23 PM
I sprung for the rebuilt carbs. I figure I can spend a whole lot of time on tuning the rebuilt ones and putting blockoff plates on them for the extra 400 bux.
YIPEE!!!! PROPER CARBS!!!!! anyone want some weber progressive toilet paper now? (IMG:style_emoticons/default/biggrin.gif) |
SGB |
Aug 27 2007, 10:41 PM
I believe Brian has some sweet parts he has never used. Do theycome with any jets?
it is no real mystery- try 55 idle, 125 main, 180 air. |
purple |
Aug 27 2007, 10:44 PM
Thanks for the tip scott. I'm going to find as many manuals as i can for these, but just before I start, how many jets of each do i need? what do those jets you mentioned do?
type11969 |
Aug 28 2007, 06:35 AM
4 of each, 1 per barrell.
Check your vent size, make sure it is not huge otherwise it may be tricky to tune. Especially if you have a low revving bus engine. |
So.Cal.914 |
Aug 28 2007, 07:56 AM
Cool, now you need NO, a blower, a couple turbos and a fire extinguisher. (IMG:style_emoticons/default/smile.gif)
SGB |
Aug 28 2007, 03:34 PM
4 of each, 1 per barrell. Check your vent size, make sure it is not huge otherwise it may be tricky to tune. Especially if you have a low revving bus engine. "vent" = Venturi, the narrowing openning inside each barrel. Usually a 40 idf carb comes with 28mm venturis. It is stamped on the venturi itself. I see the ad says "jetted for 2.0" so it is very likely you got the jet sizes I listed. One thing I see that is good is that your new carbs have "jet doctors"- those tubes sticking up from the top- that will help prevent problems in high G turns (I don't have 'em YET) |
Lo-Fi Version | Time is now: 16th May 2024 - 04:00 AM |
