Did the Exxon Valdez run aground in my garage?, Q: Do I rebuild engine or sell the money & time pit |
rjames |
Aug 28 2007, 12:34 AM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Stupid effin car. Pardon me whilst I vent.
I bought the thing 3 years ago, promptly started doing the following: Removed floorboard tar Replaced relay baord replaced injectors replaced fuel lines (twice) Replaced all hoses Replaced rear reflector Replaced seats Rebuilt pedal cluster Installed new clutch cable Installed new Accel cable Fixed turn signlals Fixed Ebrake Found that the floorboard/battery tray were rusted through so I bought a welder and taught myself how to weld and then proceeded to: Weld in new drivers floorboard POR15'd all floorboards Welded in new seat mounts Cut out rust from longs and welded in my fabricated patches Installed stock front sway bar after welding on U-tabs Welded in new battery tray Removed small bit of rust from front trunk channel and Por15'd it and re-installed nice rubber seal Replaced bug steel wheels with polished Mahles Installed new carpet replaced broken fog lamp replaced cracked tail light lens replaced ground strap from tranny replaced all shifter bushings de-rusted inside of gas tank, and re-painted replaced fuel pump replaced center console bulbs Installed the JWest engine lid thingy so I could use the stock springs after the original hinge broke off And I just got early bumpers ready to be repainted then installed in place of the heavy '75 ones Here's where I'm at now: I heard some knocking in the engine and decided to learn how to do a valve adjustment, and after much reading of posts here, I tackled it. Unfortunately I have hydraulic lifters (I knew the car had them when I bought it, but didn't know what it meant). After wrestling with the stupid valve covers I made adjustments as instructed by many of the postings here (don't worry, I didn't adjust them as though they were the non-hydro type), and when I got the valve covers back on I drove around and had the same freakin' clackity-clack noise that I had before, only now I had oil dumping out all over my right heat exchanger. I guess the valve cover either isn't seated properly, or the new cork gastket isn't doing it's job. Hopefully I just need to reseat the valve cover. Either way it looks like a major oil spill on my garage floor. (IMG:style_emoticons/default/headbang.gif) So here I am with 2 questions: 1) How the FUCH do you get the valve cover spring thing (bail?) back on without moving the cover? I can pry the thing off easily enough by popping off one side of the spring, but when it comes to re-installing it, it won't push up over the valve cover unless I use the a big-ass screw driver and the heat exchanger for leverage (something I know I shouldn't do). 2) since my engine is still knocking loudly, or ticking, or puking or whatever, do I assume it needs a rebuild? If so, can it be rebuilt back to specs with NO hydros?, or should I just sell the car and take a big $ loss on the original purchase price? I just found out that I may have my first little one on the way and there isn't enough $$ or time to do what I would like to do, which would be to buy a Raby kit, find a 6, or rebuild it myself. Oh yeah, how much does a rebuild typically cost? (It's a 2 liter). (IMG:style_emoticons/default/sad.gif) |
Twystd1 |
Aug 28 2007, 02:07 AM
Robert. the valve cover goes on upside down. With the VW logo at the top. (pointing towards the sky)
And yea I just use a BIG screw driver to pop em on... Just like you. Ask for some help from the Washington guys that build engines. Theres a covy of them up your way. They may well be able to help you discern the knocking sound and what the hell it may be. I highly suggest you DON'T drive the car until you figure out what is making the sound. The Boyzz here can help ya out with a rebuild. A cheap rebuild costs me round 1500 bucks and I do all the disassembly and assembly. Thats done right and to stock specs. This the the engine only. Not the induction, exhaust or ignition, tin or anything ancillary to the block, barrels and heads. This assumes the heads are repairable. And not cracked beyond repair. Guys on this board have done it for less. Just depends on your mechanical ability. And KNOWING a very good type IV machinist that knows more than us. (lucky me, I have 2) And sourcing parts at the best price possible. Add 300+ plus bucks for a Jake 9550 and lifters + oil and whatever else he dictates. (his cams and parts are some of the very best.) Thats my experience. Yours may well be different. Clayton NOTE: IMHO A very simple style performance build starts at around 2800 bucks and can go up fast after that. Last one I helped on for a guys race buggy was 12K. And that was cheapo rebuild when you consider the end result. |
So.Cal.914 |
Aug 28 2007, 08:15 AM
QUOTE Did the Exxon Valdeze run aground in my garage? Easy to tell, set a very large Hav-a-heart trap in the middle of your garage. Place a bottle of whiskey in for bait...and wait. In the morning check the trap, If you see oily foot prints and a sea fairing drunk in the trap, and he answers to Captain Joseph Hazelwood, Then yes it was the Exxon Valdez. (IMG:style_emoticons/default/thumb3d.gif) As I remember the oil pumpers (hydro lifters) had a different case. But you don't need a 2.0 case, you can use a 1.7 case if you want. And a Major congrats on the future you running around. (IMG:style_emoticons/default/smile.gif) |
rjames |
Aug 28 2007, 11:19 AM
QUOTE Robert. the valve cover gasket goes on upside down. With the VW logo at the top. (pointing towards the sky) Yup, I put it on upside down (which is the same way it was when I took it off). Funny that the driver's side was right-side up when I took it off, and seemed to only fit tight when I put it back the same way. Getting the covers off wasn't too bad once I realized I could just pop the spring off- it's getting them back ON that's been a beyatch. Clayton- thanks for the additional rebuild info, I'll be looking into local shops to see what they charge- I'd love to do it myself, but full-time work & full-time school doesn't leave me much free time to tackle such a project. QUOTE And a Major congrats on the future you running around. Thank you, it's a bit too early to be sure (wife just did the pregnancy test) so lots can happen between now and 9 months out, but excited at the possibility just the same (IMG:style_emoticons/default/smile.gif) |
brer |
Aug 28 2007, 11:35 AM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
you can put some grease on the valve cover where the bail rides to make it easier.
rjames |
Aug 28 2007, 03:50 PM
Any chance my clicking noise could be from the timing being off? I have never checked that, although I know it was done about 5k miles ago. Or is clicking from the engine a good indicator that a rebuild is necessary?
SLITS |
Aug 28 2007, 05:19 PM
"Clicking," is a very nebulous term.
Pushrods not seated correctly Adjustment screws sticking out to far and hitting valve cover Loose rocker pedstal studs collapsed lifters worn pistons something in the impeller housing loose impeller cracked alternator mount or pulley loose tin loose heater components (warm air guides,etc.) And the list goes on and on. To check for rod knock .... start engine and have someone hold the RPMs at about 2 - 2.5k. If clicking is heard, pull each spark plug wire off .... if clicking goes away on one paticular cylinder, you have began isolating the problem. Knocking can be timing related ....... Get a mechanics' stethoscope and listen to various areas of the engine .... isolate area where sound is coming from before you start throwing bucks (Oh, a long screwdriver held up to the ear works too .... unless your deaf like me) |
So.Cal.914 |
Aug 28 2007, 05:59 PM
[quote]
Get a mechanics' stethoscope and listen to various areas of the engine .... isolate area where sound is coming from before you start throwing bucks (Oh, a long screwdriver held up to the ear works too .... unless your deaf like me) Hi Ron: If the above was not a joke, I would like to share something with you. A friend of mine has a brother that is hearing impared. The school he went to to learn to funtion as a deaf person taught him to put a wood dowel (or screwdriver) behind the ear in the little indent where the bottom of the ear meets the head. I guess the eardrum is closer their, so the vibrations are stronger.Anyway, if you knew this already...Nevermind. |
SLITS |
Aug 28 2007, 06:44 PM
No joke .... my hearing loss is in the range of womens'/childrens' voices and is getting worse (meaning I can ignore everyone).
The screwdriver acts much as the wooden dowel you speak of ... it actually transmits the sound vibrations to the bone mass surrounding the ear drum as I remember and a hearing aid does somewhat the same .... amazing what you can hear inside an engine. The stethoscope makes you look more professional ..... (IMG:style_emoticons/default/biggrin.gif) |
SGB |
Aug 28 2007, 06:48 PM
If it is a TICK_TICK_TICK, It is likely those hydro lifters I think (BTDT). Try some marvel mystery oil. Get a can of "valve medic" or some other solvent if that does not work. If it is worse, like CLANK_CLANK_CLANK, maybe teardown is needed, but unless it is really sick, I would try the above.
rjames |
Aug 28 2007, 10:41 PM
Ticking sound speeds up with engine speed, sound definitely seems to be coming from the passenger side. Hydro lifters yes, but it didn't make this sound until about 4 weeks ago, and then it got progressively louder. Reminds me of when my sister forgot to put oil in her oil burning toyota and damn near fried the engine. She was driving it on practically no oil, and then it developed a similar sound.
When adjusting the valves I set them to .006 to get the lifters pumped up, drove around for 10 minutes, then set them to zero plus 1 turn. Didn't change the sound at all. I will try pulling plug wires and see if it affects the noise.... Thanks for the continued input guys. |
jk76.914 |
Aug 29 2007, 05:37 AM
Pressurized oil is forced into a chamber in the bottom of the lifter through a check valve. When the lifter begins to move up the ramp of the cam, the check valve closes to trap the oil in that chamber and make the lifter act like a solid lifter and open the valve.
A tick is almost always caused by a piece of grit in the check valve, allowing oil to reverse flow out of the chamber when the valve opens. Then when the valve is closed, there isn't enough time to refill and readjust before it's called upon to open again. Other less likely possibilities- foamed oil (lots of air, which compresses), low oil pressure, bad lifter (too much clearance between plunger and body) Clean oil is the real key to keeping the hydros quiet. Did the PO change the oil regularly? You can get a sense from the rocker gear but also from the screen. I'd probably do an oil change maybe to 10W-30 with something in there to clean it out, then another change in maybe 500 miles to a quality 20W-50. If that doesn't work, you'll need to find which lifter is ticking and rebuild it. It's not a bad or expensive job, and it's a good opportunity to visually check the cam lobe using a flashlight through the lifter bore. Also carefully check the lifter base for wear (shouldn't be concave) - or worse (galling). When you reassemble the lifter, leave it empty. These days the cam grinders almost unanimously say to assemble with lifters empty. It'll pump up faster than it will bleed down, and it won't be holding the valves open while it's pumping up. It's noisy until it settles in-like the hammers of hell. I've done a lot of hydro work in the past year, and on my 914 it take about 8 miles at moderate RPM- maybe 3000- and then all of a sudden it goes quiet. If you replace the lifter, use all of the practices as for a new engine breakin as regards oil additives. And don't use Meyle lifters. Get them from VW or Isky. What weight oil are you using? The heavier the oil, the longer they will take to self adjust, especially when cold. I'm using a 20W-50 with my hydros. How far did you drive it after the lifter adjustment? It takes a while to adjust down using the process you used, and until they've adjusted the engine would run a bit rough. They'll actually adjust down while the car is sitting because of the constant force of the valve spring on them. Good luck! |
rjames |
Aug 29 2007, 11:26 PM
jk76.914, thanks for the reply, I appreciate it. I was actually following one of your posts in a previous thread on how to adjust them.
Have patience with me here as I'm new to working on engines, but I can learn. I'm using 5w30 mobile 1 synthetic, and have done 2 oil changes since adjusting the valves, and have changed the oil every 2k miles. I drove around for about 10 minutes after both valve adjustments (the first was when I set the valves to .006, the second when I set them to 0 plus 1 full turn). I didn't drive anymore than 10 minutes because the noise seemed to be getting louder than it was originally, and also because it turned out that I didn't have a good seal on the valve cover and I ended up with oil all over an exchanger and decided to call it an evening at that point. Showing my ignorance, but I am assuming that the engine needs to come out if I want to try and look at the cam lobe (and what I would I be looking for?). I don't know what kind of lifters I have, but are they interchangable? If I have Meyle's, can I just replace a bad lifter with another brand? If I replace one, do I need to replace them all- that is if I can determine which lifter is the culprit. Can I do this with the engine in the car? Also, do I run the risk of causing major damage by trying to get the lifter to self adjust? Lastly, there is no noticible loss of power since the noise started happening. Sorry for all the questions, I feel like a big lame-o, and I'm not looking forward to dumping oil all over myself again when I remove the valve covers. (IMG:style_emoticons/default/mad.gif) |
Rand |
Aug 30 2007, 01:20 PM
Isn't 5w30 *really* thin for these motors? I run 20w50.
Hang in there Robert. |
SGB |
Aug 30 2007, 06:15 PM
jk76.914, thanks for the reply, I appreciate it. I was actually following one of your posts in a previous thread on how to adjust them. Have patience with me here as I'm new to working on engines, but I can learn. I'm using 5w30 mobile 1 synthetic, and have done 2 oil changes since adjusting the valves, and have changed the oil every 2k miles. I drove around for about 10 minutes after both valve adjustments (the first was when I set the valves to .006, the second when I set them to 0 plus 1 full turn). I didn't drive anymore than 10 minutes because the noise seemed to be getting louder than it was originally, and also because it turned out that I didn't have a good seal on the valve cover and I ended up with oil all over an exchanger and decided to call it an evening at that point. Showing my ignorance, but I am assuming that the engine needs to come out if I want to try and look at the cam lobe (and what I would I be looking for?). I don't know what kind of lifters I have, but are they interchangable? If I have Meyle's, can I just replace a bad lifter with another brand? If I replace one, do I need to replace them all- that is if I can determine which lifter is the culprit. Can I do this with the engine in the car? Also, do I run the risk of causing major damage by trying to get the lifter to self adjust? Lastly, there is no noticible loss of power since the noise started happening. Sorry for all the questions, I feel like a big lame-o, and I'm not looking forward to dumping oil all over myself again when I remove the valve covers. (IMG:style_emoticons/default/mad.gif) Oh boy another Lame-O! Man, I've done ALL that and worse. The engine doesn't have to come out to look at a lifter, but it does get kinda involved in some valve rocker assembly and push-rod tube removal. That oil is way too thin. It needs 50 wt. I still vote for a can of marvel mystry oil too _but not with the 30 wt oil With the hydrualic cam, it probably has webcam supplied lifters (mine does). Don't jump to any hasty conclusions. Before you take anything apart, lets reflect.... when you did the valve adjust, were any wa-ay off? Did any seem to stick out farther when the rocker was not pushing the valve open? If you do take the rocker assembly off, keep track to put it all back in the same spots I've got a pic I've got to find where I replaced the seals on the push-rod tubes that shows what I'm talking about- stand by... |
rhodyguy |
Aug 31 2007, 09:31 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
rob, did jerry have any info for you?
k |
rjames |
Aug 31 2007, 10:30 AM
rob, did jerry have any info for you? k Hey Kevin- I'm going to call him today, I finally found the receipt from the lonblock rebuild that the PO had done in '97. Funny, the receipt shows a 12 year warranty! (IMG:style_emoticons/default/laugh.gif) BTW, the seat looks great in the car, thanks again. I'm sure it will look even better when the car is running again. (IMG:style_emoticons/default/smile.gif) |
rjames |
Aug 31 2007, 10:34 AM
QUOTE Before you take anything apart, lets reflect.... when you did the valve adjust, were any wa-ay off? Did any seem to stick out farther when the rocker was not pushing the valve open? If you do take the rocker assembly off, keep track to put it all back in the same spots I've got a pic I've got to find where I replaced the seals on the push-rod tubes that shows what I'm talking about- stand by... Thanks Scott, here's the answer to your questions: When I did the valve adjustment, none of the valves seemed off- I had to lossen them all by at least 1 turn before they weren't touching anymore. None of them necessarily seemed to stick out farther when the rocker was not pushing the valve open, but then again it's possible. I could try and actually measure how far they are out when fully extended. Looking forward to pics, I'll try and take some myself on Saturday. Thanks again! -R |
jk76.914 |
Aug 31 2007, 11:09 AM
Back to the oil- I agree that the 5w-x oil is thin for these, and that 20w-50 is a better choice. You want the oil to be thin enough to bleed down when it needs to to self-adjust, but too thin and it will bleed down when you don't want it to and it'll keep the adjustment on the loose side. This is mainly at idle and slow speed.
So sounds like the consensus recommendation is to put something in to clean the system, run it for awhile, and then change the oil to a quality 20W-50. There are lots of threads here about which oil to use. Also, check out the LN Engineering website for their article on oil. As far as what additive to put in? I have no experiece with any of them. I've heard AT fluid works, but I'd probably try Marvel Mystery Oil myself. Or go down to FLAPS and see what they've got on the shelf that's a reputable brand, and then follow the instructions. Keep in mind, if your real problem is the thin oil, the additive may clean out the lifters, but they'll still tick until after your oil change. Jim |
jk76.914 |
Aug 31 2007, 11:26 AM
I'm using 5w30 mobile 1 synthetic, and have done 2 oil changes since adjusting the valves, and have changed the oil every 2k miles. Showing my ignorance, but I am assuming that the engine needs to come out if I want to try and look at the cam lobe (and what I would I be looking for?). Also, do I run the risk of causing major damage by trying to get the lifter to self adjust? I just reread your earlier post. Mobil 1 does quite a good job cleaning out engines on its own. In fact, I blew a Saab engine by switching over to Mobil 1. Seems the PO had NEVER changed the oil, and when I started with my Mobil 1 and regular changes, it loosened up so much crud that it blocked the pickup screen. I coasted to the side of the road and shut it off when the oil pressure light came on, and after a tow and $5000 for a used engine, I was off and running again. The inside of the engine looked like it was covered with burned on meatloaf. From this, I'd speculate that your engine is probably already pretty clean inside. (After my Saab experience, I'd check the oil screen though!) So you might want to just go right to the oil/filter/screen change and see if that doesn't fix your problem. You don't need to take the engine out to replace a lifter and do a visual on the cam lobe, as SGB pointed out earlier. He also said- don't jump to any hasty conclusions! Chances are your engine is just fine. My problem with Meyles is getting oil to the head, not ticking. One issue at a time. IFF the ticking is the lifter, there's little chance of major engine damage as you work through this. Jim |
Lo-Fi Version | Time is now: 9th June 2024 - 05:10 PM |
