Got some new suspension bits from a friend!, Tarett 914 Monoball Rear Shock Mounts!! |
hwgunner |
Oct 12 2007, 12:06 AM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
Here are some new 914 suspension bits that I got in the mail today. Check out the pics.
Attached thumbnail(s) |
hwgunner |
hwgunner |
Oct 12 2007, 12:07 AM
McMark |
Oct 12 2007, 12:13 AM
Very cool!
TimT |
Oct 12 2007, 12:47 AM
Looks like replacements for the front upper strut mounts
hwgunner |
Oct 12 2007, 12:49 AM
Looks like replacements for the front upper strut mounts I just realized that there really is nothing in the pictures to give a clue to the size. I will fix that tomorrow with another picture. (IMG:style_emoticons/default/beer.gif) |
TimT |
Oct 12 2007, 12:53 AM
then they could be spherical mounts for the rear shocks (upper mount)
hwgunner |
Oct 12 2007, 12:59 AM
(IMG:style_emoticons/default/slap.gif)
then they could be spherical mounts for the rear shocks (upper mount) |
Aaron Cox |
Oct 12 2007, 11:20 AM
front monoball kits?
Chris Pincetich |
Oct 12 2007, 12:41 PM
then they could be spherical mounts for the rear shocks (upper mount) (IMG:style_emoticons/default/agree.gif) I've seen those on Chris Foley's web page, or ones that look just like them. Either by themselves or in conjunction with other mods they were used to raise the rear suspension geometry for lowered racers. |
hwgunner |
Oct 14 2007, 08:15 PM
then they could be spherical mounts for the rear shocks (upper mount) (IMG:style_emoticons/default/agree.gif) I've seen those on Chris Foley's web page, or ones that look just like them. Either by themselves or in conjunction with other mods they were used to raise the rear suspension geometry for lowered racers. Not Chris's. these are Tarett Engineering. 914 Monoball rear shock mounts. They mount with the red part in the shock housing and the nut on top. they will not interfere in the mounting of the targa top in the trunk. They will rais ethe car just a hair in the rear but I will measure on my car before I replace and give a better quantitative overview once I get them installed. If you look close these had to be modified and have a little shaved off the top gold portion. This will be corrected for the first real production run. Keep your eyes peeled as I will probably be spear heading an "Introductory Offer" available right here for 914world members. (IMG:style_emoticons/default/driving.gif) |
majkos |
Oct 14 2007, 08:34 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Lou W |
Oct 14 2007, 11:13 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
then they could be spherical mounts for the rear shocks (upper mount) (IMG:style_emoticons/default/agree.gif) I've seen those on Chris Foley's web page, or ones that look just like them. Either by themselves or in conjunction with other mods they were used to raise the rear suspension geometry for lowered racers. Not Chris's. these are Tarett Engineering. 914 Monoball rear shock mounts. They mount with the red part in the shock housing and the nut on top. they will not interfere in the mounting of the targa top in the trunk. They will rais ethe car just a hair in the rear but I will measure on my car before I replace and give a better quantitative overview once I get them installed. If you look close these had to be modified and have a little shaved off the top gold portion. This will be corrected for the first real production run. Keep your eyes peeled as I will probably be spear heading an "Introductory Offer" available right here for 914world members. (IMG:style_emoticons/default/driving.gif) I'll be watching, I have a set for the fronts and was wondering what they were going to do for the rears. (IMG:style_emoticons/default/popcorn[1].gif) |
RON S. |
Oct 15 2007, 11:45 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
angerosa |
Oct 15 2007, 12:07 PM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Excuse my ignorance but...
What do these do and why would I want them? |
Aaron Cox |
Oct 15 2007, 01:32 PM
eliminates the rubber strut mounts.....
zero play, all energy is put into the chassis and the damper itself. hard to 'performance tune' your suspension, when the rubber is not consistent every time |
angerosa |
Oct 15 2007, 01:43 PM
Got it - Thanks - makes sense. no play, little stiffer.
majkos |
Oct 16 2007, 09:41 AM
How much? (IMG:style_emoticons/default/popcorn[1].gif)
Chris Pincetich |
Oct 16 2007, 10:51 AM
If you're gonna work on a deal, can you also get fronts? (IMG:style_emoticons/default/beerchug.gif)
Joe Ricard |
Oct 16 2007, 11:36 AM
Does not make anything firmer.
But does make the shock do it's job instantly. Hence you have a better control of the tire as it contacts the road. Probably does not make the car lower either unless the upper spring perch is re-located. Still have to over come the rubber bushing at the bottom of the shock. Those pieces are dead sexy however. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:18 PM |
