| JeffBowlsby |
Nov 8 2007, 01:24 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,233 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
My oil pressure light often comes on briefly, especially when the engine is cold and when the idle is low.
2.0L engine, stock configuration, stock FI, 950-rpm idle, 4 quarts of 30-wt Castrol always. 114K miles, slight smoking, have not checked compression. 1/2 qt oil usage with every fill-up, I keep it topped up. Are the oil pressure valves just gummed up? Or is my oil pump or oil pressure sender worn out? Why is this and what can I do about it? |
| dr914@autoatlanta.com |
Nov 8 2007, 03:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,233 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
My oil pressure light often comes on briefly, especially when the engine is cold and when the idle is low. 2.0L engine, stock configuration, stock FI, 950-rpm idle, 4 quarts of 30-wt Castrol always. 114K miles, slight smoking, have not checked compression. 1/2 qt oil usage with every fill-up, I keep it topped up. Are the oil pressure valves just gummed up? Or is my oil pump or oil pressure sender worn out? Why is this and what can I do about it? Install a new switch first and see if that is the problem. Usuallly the light comes on when hot not cold if the oil pressure is low. |
| Cap'n Krusty |
Nov 8 2007, 03:26 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Yup. And put 20w50 in it. The old Porsche "thing" about multi-grade oils is long gone, and you'll get better lubrication in both cold and hot weather with 20w50. The Cap'n
| Aaron Cox |
Nov 8 2007, 04:18 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
whats your oil temp look like?
hot oil is thin oil..... thinner oil is harder to make adequate pressure with |
| Garland |
Nov 8 2007, 11:50 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Yup. And put 20w50 in it. The old Porsche "thing" about multi-grade oils is long gone, and you'll get better lubrication in both cold and hot weather with 20w50. The Cap'n (IMG:style_emoticons/default/agree.gif) Doing the same with 20/50 for 30 years in mine. |
| Elliot Cannon |
Nov 8 2007, 11:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
whats your oil temp look like? hot oil is thin oil..... thinner oil is harder to make adequate pressure with He said it happens when the engine is COLD ya 'tard.!! (IMG:style_emoticons/default/av-943.gif) |
| Twystd1 |
Nov 9 2007, 12:38 AM
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
GeeeZZZ Elliot,
(He doesn't know what TARD means) C |
| Bleyseng |
Nov 9 2007, 09:01 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
BradPenn 20/50w or that Mobil 1 20/50w AirCooled Motorcycle oil
and your motor will love it. |
| BMartin914 |
Nov 9 2007, 09:05 AM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Valvoline 20w50 racing is also readily available.
Lo-Fi Version | Time is now: 14th April 2026 - 06:53 PM |
