Fiid's Project Progress Thead., The Legend of Narparu |
fiid |
Jan 3 2004, 12:59 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
This evening I bolted the dummy transmission to the subaru motor.
Please excuse the mess in my garage. Here is an aft view. Attached image(s) |
DNHunt |
Jan 8 2004, 08:21 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Fiid
MegaSquirt can certainly handle the fuel side of the engine. I'm not sure about the ignition side of it. The problem is driving all the coils. Currently, it is working with 1 coil driver and 1 coil with sparkplug wires or, with the Ford EDIS system which is wasted spark and uses coil packs and sparkplug wires. To run the coil on plug systems you will need 4 coil drivers and a cam sensor to determine which cylinder is to fire. Unless you can figure out how to tap the stock ignition system prior to the cam position sensor you will probably have to give up the coil on plug system. That's way more than I'm capable of. I've been trying to figure a way to put COP on my car but I can"t get past the cam timing issue. I've got 8 Ford coils from a Crown Vic siting on my bench and they'll probably sit there for a while until someone with some intelligence figures out how to use Mega------- to run COP. Dave |
Lo-Fi Version | Time is now: 17th May 2024 - 05:15 PM |
