I NeedHelp!!!, Carbueration problems |
mikalle76 |
Mar 19 2003, 08:07 AM
Newbie Group: Members Posts: 3 Joined: 19-March 03 Member No.: 443 |
(IMG:style_emoticons/default/sad.gif) I need help on converting the niner to carbueration.
what all do I need? My fi computer was shot. I want to know what I need to do as far as wiring and all. Thanks |
Dave_Darling |
Mar 21 2003, 10:32 PM
Let's see.... Carbs, linkage, manifolds. Fuel pump and regulator. Air cleaners. That's an absolute minimum. The stock distributor can be used, though a lot of people like to swap to an 009 (yuck!!) or 050 centrifugal-advance-only distributor. If you've got $$$, the Mallory is supposed to be a very good distributor for carbed cars.
Don't run the fuel pump off of the coil; you want all the juice going to the coil you can. You can plug in the EFI power supply relay and plug the pump wire into the right-front pin on the four-pin connector on the relay board. If you're putting the pump up front, you can probably run it off of a switched circuit on the fuse panel. --DD |
Lo-Fi Version | Time is now: 26th May 2024 - 12:22 AM |
