engine transplant |
engine transplant |
Sallachie |
Dec 27 2007, 03:11 AM
Newbie Group: Members Posts: 11 Joined: 27-December 07 From: Victoria, BC Member No.: 8,505 |
Hello. I'm new to the forum, and to 914s. I recently bought a '73 914 that is a project car. Pan is solid, but someone has put a nice rollcage in the car and cut of the sail panels. I've picked up a 911 front suspension and spare side shifts.
I want to put a V8 in to the car, but which one? I've got a line on an Olds 215. It's a light engine, but limited parts available. I'm making a street toy with a bit of autocrossing. I want it to beat my '73 Datsun 240Z, which is pretty quick. Any opinions??? |
Dec 27 2007, 01:51 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if you have some money to spare, go with a create 350 ... reliable, solid, *new* and plenty of umpf ... i'm a firm believer in "do it once, do it right" ... (IMG:style_emoticons/default/bye1.gif) Andy PS: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Sallachie |
Dec 27 2007, 02:07 PM
I thought about a 350, but a couple concerns;
350 weighs #550 compared to #200 stock 1.8L Will the side shift transaxle handle the torque of a 350? I thought that I'd ask people who actually own similar cars and check for opinions. Try and learn from other peoples experience... Thanks |
toon1 |
Dec 27 2007, 02:52 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Ton's and ton's and TON'S of info in the search.
V-8 conversions are popular, the 901 trans. will handle the HP. If you have acess to a subaru engine, they produce alot of HP and the handling will be the same since it's a flat 4. Your choice, (IMG:style_emoticons/default/welcome.png) |
jimkelly |
Dec 27 2007, 03:04 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
http://www.renegadehybrids.com/indexx.html#
everything you need for v8 or subaru conversion is right here. just don't forget to upgrade your suspension and brakes. jim |
marks914 |
Dec 28 2007, 06:22 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
It all depends on what you want to get out of the car...
If you are looking for cheap, and you can fab a bit, go with the 215 The SBC is usually the V8 of choice because of the availability of kits to install them. I used a desert hybrids conversion www.deserthybrids.com (seen on '08 Hot Rod)./ I tried to buy some stuff from Renegade, but it was too much of a hassle. Kennedy Engineering makes tons of adapters and clutches for conversions http://www.kennedyeng.com/ The stock trans is good for 300 ft/lb of torque, but the gears are a tad short. I am running a 400+HP Chevy 302 in mine, high HP, low torque with the 901 trans with tall gears. The cars are alot more fun with a V8 in my opinion. I did the 302 because it revs like a mother and drives more like a porsche than a torquey 350. Mark (IMG:http://inlinethumb08.webshots.com/5831/2363509080057582025S600x600Q85.jpg) (IMG:http://inlinethumb07.webshots.com/6534/2746009050057582025S600x600Q85.jpg) (IMG:http://inlinethumb17.webshots.com/5136/2938891350057582025S600x600Q85.jpg) (IMG:http://inlinethumb43.webshots.com/3178/2696818300057582025S600x600Q85.jpg) (IMG:http://inlinethumb18.webshots.com/30481/2041932740057582025S600x600Q85.jpg) (IMG:http://inlinethumb15.webshots.com/31438/2417293290057582025S600x600Q85.jpg) (IMG:http://inlinethumb19.webshots.com/28242/2525888240057582025S600x600Q85.jpg) |
GS Guy |
Dec 28 2007, 07:47 AM
Member Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
Hey Mark,
Not so sure about the 302 Chebby being easy on the 914 trans anymore..... Anyone see the latest PHR magazine with the Engine Masters Challenge? One crew entered a 302 Chev. - Eagle crank, AFR heads and a big whopp'n cam - 340ft/lbs @ 2500 - it went up from there maxing at 425 @ 5400! 498hp @ 6500. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/idea.gif) That's one bas-a$$ 302! Runs on pump gas too! Wonder if a Toyota/Lexus V8 cold be shoehorned in? Jeff |
Sallachie |
Dec 28 2007, 01:53 PM
That's a very nice 302. The 302 is a 289 block with a 327 crank? Special pistons/rods for that combo? I was going to go with a Kennedy adapter, but they have such a selection it makes for many choices.
I want to keep the car a driver. I was thinking a bit of a rough idle (280-ish duration), but I must have the V8 sound. I also wanted 180 degree headers, similar to a Pantera. I do all fab, mechanical, and bodywork myself. I didn't want to spend $10K on an engine, and not over power the 914 transaxle. Custom speed parts for Porsche can be stupid expensive, and I'd like to build the car for about $10K max. Aero body kit by http://www.betterbodiesmotorsport.com I thought someone has already hacked my car, so just work with it. I want my 914 to beat a Datsun 240Z! |
Dec 28 2007, 02:39 PM
I want my 914 to beat a Datsun 240Z! i did that with my stock d-jet 1.7L 914 !!! (IMG:style_emoticons/default/shades.gif) but it did involve curves and real driving, not the straightline dragging ... (IMG:style_emoticons/default/driving.gif) Andy |
marks914 |
Dec 28 2007, 04:27 PM
That's a very nice 302. The 302 is a 289 block with a 327 crank? Special pistons/rods for that combo? I was going to go with a Kennedy adapter, but they have such a selection it makes for many choices. I want to keep the car a driver. I was thinking a bit of a rough idle (280-ish duration), but I must have the V8 sound. I also wanted 180 degree headers, similar to a Pantera. I do all fab, mechanical, and bodywork myself. I didn't want to spend $10K on an engine, and not over power the 914 transaxle. Custom speed parts for Porsche can be stupid expensive, and I'd like to build the car for about $10K max. Aero body kit by http://www.betterbodiesmotorsport.com I thought someone has already hacked my car, so just work with it. I want my 914 to beat a Datsun 240Z! The 302 is a real DZ, 1178 forged 3" stroke large journal crank, 302 block (same as a 327-350) 302 pistons cut down to 10.4:1 so I can run it on pump gas. It has a more Porsche feel than a 350. A 283 or 327 are good choices as well as being a bit less expensive. I kept the power up high so that when it comes on I am already moving. The sound is what really wakes people up though. Mark |
Katmanken |
Dec 28 2007, 07:44 PM
That's a front spoiler I haven't seen before.
Any clue where it comes from? If it's flexy, it's probably off a production car (not 914) Ken |
Sallachie |
Dec 28 2007, 10:00 PM
It's a fiberglass piece. One of my buddies thought it may be from a civic body kit part, but I really don't know. Someone obviously had plans for this car, but probably ran out of money, or talent. Works for me though...
It's currently running with one Weber, but the brakes stick. I bought the car and a truck load of parts for $550, then drove it on the trailer. I haven't started this 914 project as I'm currently invloved with a mini. I'm trying to get all the parts in place before I start on the Porsche. People say that the transaxle can handle 300hp, but a weak 1st gear? I've looked at the trans and the gears inside, and I have reservations about pushing a heathly SBC into it. I've broken much bigger parts. |
Twystd1 |
Dec 28 2007, 11:26 PM
Me thinks thats a 1988 to 1991 Honda Accord "aftermarket" front air dam.
I have also seen something similar on 90s vintage BMW 325, 320s and 318s. Hmmmmmm... That makes me think of some more possibilities. Clayton |
michaelt55 |
Dec 29 2007, 01:55 AM
Graduate of Life's experiences Group: Members Posts: 438 Joined: 2-September 06 From: Richmond, Texas Member No.: 6,753 Region Association: None |
Done right..a 215 is a great balanced powerplant. I have one...
Its 200 + HP and only 40 -50 lbs heavier than a stock 4.... Michael |
Lo-Fi Version | Time is now: 19th May 2024 - 03:12 AM |
