Why do I need a $200 engine stand?, I already have a V8. |
TeenerTim |
Dec 28 2007, 01:12 PM
Senior Member Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
OK. I'd rather spend that money on engine parts than some fancy schmancy engine stand when I already have a stand that will hold an American V8. The brackets are adjustable so I should be able to make them fit. Is there any reason why I shouldn't?
(IMG:http://www.automotion.com/aux_incl/images.ashx?i=skuimages/large/102213/106293.jpg) |
Beamer13 |
Dec 28 2007, 01:26 PM
Member Group: Members Posts: 303 Joined: 8-November 07 From: Midwest Member No.: 8,308 Region Association: Upper MidWest |
Here is what I did, with the regular old Harbor Freight engine stand. I only have it on with 3 bolts, but you could adjust one of the arms to attach the 4th. but it works fine with just 3.
as you can see, the arm from the stand on the left ( as you're looking from the stand over the engine is not connected due to reach. Just have a couple guys there, attach the arms to the engine while on the ground then heave it up and into the stand, put the pin in and you're set!!! Ron |
McMark |
Dec 28 2007, 01:29 PM
That stand isn't designed for a V8. Using the stand you have should be fine.
What are you doing with the motor? Storing? Rebuilding? We are talking about a V8 motor and not a Type IV, right? (IMG:style_emoticons/default/confused24.gif) |
flippa |
Advanced Member Group: Members Posts: 3,177 Joined: 7-May 07 From: Boston, MA Member No.: 7,720 Region Association: North East States |
I have the same one & it works fine. I think the other one is made to hold one half of the engine if you completely break it down. DOn't have one, so I'm not really sure.
THe cheap one may not be as pretty as the other one, but if it adjusts enough to fit, it should be fine. |
toon1 |
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
the adapter that is used for the TIV motor will distribute and support the weight of the engine better and is easier to use.
The setup you have will work( I use the same) but be carefull, if done wrong it will break the engine case. |
TeenerTim |
Dec 28 2007, 01:36 PM
That stand isn't designed for a V8. Using the stand you have should be fine. What are you doing with the motor? Storing? Rebuilding? I just bought a 2.0L I need to tear down and see what condition it's in. If the block and cylinders are OK I'm going to do a 96mm overbore with the Keith Black pistons, and Jake cam/valve train setup. I took the 1.7L out of the car to do the hell hole work and now one thing leads to another... edit: the stand old stand is for a V8, my engine is the TIV. |
McMark |
Dec 28 2007, 01:42 PM
You can teardown a motor with the V8 stand pictured, but I would recommend an Empi stand or the stand you pictured for buildup. Check out this thread for more opinions.
911quest |
Dec 28 2007, 01:58 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
The correct fixture is cheaper now then they were two years ago buy one and sell it later if you never need it again. Nothing is better then the correct tool.
TeenerTim |
Dec 28 2007, 02:38 PM
You can teardown a motor with the V8 stand pictured, but I would recommend an Empi stand or the stand you pictured for buildup. Check out this thread for more opinions. I got lazy. How do you spell S E A R C H ? And that was only a month ago too. (IMG:style_emoticons/default/confused24.gif) |
John |
Dec 28 2007, 02:42 PM
The correct fixture is cheaper now then they were two years ago buy one and sell it later if you never need it again. Nothing is better then the correct tool. (IMG:style_emoticons/default/agree.gif) The 5-arm Porsche style yokes made in CHINA are cheaper. They also make adapter rings for the run-of-the-mill 4-arm style stands (as shown above). You could also buy one of these if you wanted one cheap (it's only a 4-arm style) but it is only $90.00 e-bay |
TeenerTim |
Dec 28 2007, 03:21 PM
The correct fixture is cheaper now then they were two years ago buy one and sell it later if you never need it again. Nothing is better then the correct tool. (IMG:style_emoticons/default/agree.gif) The 5-arm Porsche style yokes made in CHINA are cheaper. They also make adapter rings for the run-of-the-mill 4-arm style stands (as shown above). You could also buy one of these if you wanted one cheap (it's only a 4-arm style) but it is only $90.00 e-bay Thanks for the link. That same company made a three arm version for only $68.95. I think the critical part is the number of bolts to the case rather than the arms to the mount. I bought this one and will write a review when it gets here. (IMG:http://i22.ebayimg.com/04/i/000/b7/1f/ae87_1.JPG) |
VaccaRabite |
Dec 28 2007, 04:53 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
With the 4 arm ones from HF, you can't have the fly wheel on it and have it bolted to the stand. At least, not without chewing up the teeth to your flywheel.
I really like the one (IMG:http://i22.ebayimg.com/04/i/000/b7/1f/ae87_1.JPG) I am using an EMPI stand. It works, but I can't say that I like it. Just does not feel beefy enough for me. Zach |
Allan |
Dec 28 2007, 05:44 PM
I used one of the same type of HF stands our fleet mechanics use when I rebuilt my 2.0. I just added a piece of angle iron at the bottom and was able to bolt it up at the four points on the case.
Werked gud... |
John |
Dec 28 2007, 05:59 PM
The correct fixture is cheaper now then they were two years ago buy one and sell it later if you never need it again. Nothing is better then the correct tool. (IMG:style_emoticons/default/agree.gif) The 5-arm Porsche style yokes made in CHINA are cheaper. They also make adapter rings for the run-of-the-mill 4-arm style stands (as shown above). You could also buy one of these if you wanted one cheap (it's only a 4-arm style) but it is only $90.00 e-bay Thanks for the link. That same company made a three arm version for only $68.95. I think the critical part is the number of bolts to the case rather than the arms to the mount. I bought this one and will write a review when it gets here. (IMG:http://i22.ebayimg.com/04/i/000/b7/1f/ae87_1.JPG) With the ring (or half ring type yokes, the engine is only attached to the stand with (2) bolts (or case studs) regardless of the number of arms. Back in the late 1980's or early 1990s, Porsche changed from the 4-arm yokes to the current 5-arm yokes. There was some concern with the 4-arm units supporting a fully dressed turbo engine, so the 5-arm yokes became the standard. (At least that's the rumors that I heard and pass on......) I like my 5-arm yokes that I bought from Skyway tools. My latest stand uses a clamping pivot to hold the engine at ANY angle instead of just at 90 (or 45) degree increments. Good luck with your new stand. I bet you can sell the yoke for what you paid for it when you are done with your engine. You can see my latest stand in the background of the attached picture. Attached image(s) |
sww914 |
Dec 28 2007, 06:08 PM
If you're doing a complete rebuild, you want a yoke that can support the whole engine while mounted to only the L case half. The universal engine stands can do this, but the 3,4,5 arm yokes make it a whole lot more stable and you don't need to screw around with anything, they just fit. Also, it's not always possible to get the engine weight centered on the universal stand which makes the engine difficult to turn over and maybe even dangerous. One of my co-workers had an engine (V-8) flip over while he was trying to move the stand around. It spun so fast that a spark plug jabbed him just below the knee, penetrated nicely, and lifted him off the ground. Then the whole engine/stand assembly fell over.
Engine repairs- $150.00 ER visit- $500.00 The look on his face as he was explaining it- priceless. |
burton73 |
Dec 28 2007, 06:32 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
The Chinese copy of the old tried and true Yoke at today’s low EBay price of $198... Comes in 3 colors. My 2.5ss ready to come down.
Bob Attached image(s) |
orange914 |
Dec 28 2007, 09:49 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
get a used type IV stand on e-bay, i got mine fairly cheap, just doesnt look as purdy as new
mike |
Jake Raby |
Dec 29 2007, 09:42 AM
I equipped my assembly area with 4 of the stands from Mainely Custom and I like them very much. I liked them so much I had Bob make me a unit for the race trailer as well.
I also put one of these in my video studio and will be using it to do TIV instructional videos this year. The one I used in the studio is simply an adaptor ring for the standard (cheap) V8 engine stand that supports the entire 1/2 of the bellhouse. There is no excuse for not using the correct tool... |
TeenerTim |
Feb 4 2008, 09:55 AM
QUOTE Thanks for the link. That same company made a three arm version for only $68.95. I think the critical part is the number of bolts to the case rather than the arms to the mount. I bought this one and will write a review when it gets here. (IMG:http://i22.ebayimg.com/04/i/000/b7/1f/ae87_1.JPG) As promised. Shipping was really fast and responses to e-mails were fast. You can order the stand with either the bench mount holder or the adapter for use with a free standing engine stand. I ordered the adaptor to fit my stand. The construction of the unit is first rate. Nice welds and nice finish. The only problem I had was the adaptor had several bumps on the outside that I guess were for fitting. They were just a little too big for my stand so I had to grind them off. After that they fit fine. It also came with a metal sleeve with a nut and bolt that I wasn't sure of until I went to use the mount. It then became obvious that the sleeve was a spacer so you can use the trans stud with the mount. This is really nice setup at a great price. You can contact them at [email]kraum@sbcglobal.net [/email] |
Feb 4 2008, 12:46 PM
http://www.mainelycustombydesign.com/servi...aintenance.html
Really nice guy also. He has a 914 too!!! Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 05:43 PM |
