Transmission Seal Removal, Input Shaft |
solex |
Jan 1 2008, 01:50 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
How do I get the input shaft seal out of the transmission? The input shaft gets in the way of applying an leverage.
Thanks, Dan |
TimT |
Jan 1 2008, 10:42 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE screw a sheet metal screw into the seal and use pliers to pull it out. or a slide-hammer..... Ive done that more than once |
racunniff |
Apr 5 2008, 10:55 PM
volt914 Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains |
QUOTE screw a sheet metal screw into the seal and use pliers to pull it out. or a slide-hammer..... Ive done that more than once (IMG:style_emoticons/default/agree.gif) That's how I did it today. The "seal" actually is largely metal - drill a pilot hole (being careful not to drop metal shavings into the guts of the tranny) then insert a screw on your slide hammer, bang, bang, and it pops right out: Installing the new one is as simple as finding a piece of pipe the right size to use as a drift: Per Dr. Evil in a different thread, you just need to get it in far enough that the release bearing guide tube can be installed flush. Like this: |
Lo-Fi Version | Time is now: 29th April 2024 - 02:28 AM |
