Does timing affect engine temps?, I swear my engine is running hotter... |
pete914 |
Jan 31 2008, 06:33 AM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
So,
I'm running a 1.8L stock Vacuum advance dizzy with single weber (i know...not ideal) and as I've learned the advance curve is wrong for this setup and I have pretty bad lag now before 3000rpm. I swear the engine is running hotter now. Is it because the timing is too retarded in the lower rpm range? does that affect engine temperature? Anyone running a similiar setup with a suggestion as to where to set my timing to get better performance? I don't rev it up much past 4500 Oh, and I just ordered a a centrifugal advance dizzy, if someone is using one of those with a single carb and is having luck, please tell me your settings. Thanks. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:06 AM |
