splitting rear brake calipers, Is it REALLY bad, or is it bad like the tags on matresses? |
VaccaRabite |
Feb 5 2008, 09:09 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So I am about to rebuild my rear brake calipers. Well, when I say "about" I mean Thursday or Friday.
I have read that you are not supposed to split them. Splitting the front calipers did not seem to be a problem, is there something different with the rears? I read the Pelican article on rebuilding the rears, and W/O splitting them, it seems like a real pain in the hiney. Zach |
Racing916 |
Feb 5 2008, 09:19 PM
Member Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
Not horribly hard, but you need to be patient. My father and I rebuilt mine a few months ago. The pelican parts article defiantly helps, you might have to make a tool to put the clip back on the holds the spring down. The placing of the clip takes time and finesse if you have not done it before, I am sure there is a trick.
Have fun, steve |
Racing916 |
Feb 5 2008, 09:21 PM
The rears are more difficult because of the spring adjustments for the emergency brake
Matt Meyer |
Feb 6 2008, 12:38 AM
Überlurker Group: Members Posts: 216 Joined: 2-December 03 From: Eastern Washington Member No.: 1,411 Region Association: Pacific Northwest |
Split them. The e-brake is kind of a pain in the but get a good set of circlip pliers.
Check out our own classic forum. That is the instructions I used. Eric Shea's Article on Caliper Rebuilding |
davep |
Feb 6 2008, 08:53 AM
using Eric's article is a great choice. In some ways it depends on how bad the calipers are and how much cleaning you are prepared to do. If you just want to slap new sealing rings in there, it is not too bad of a job. If you want to replace the O-ring in the back half it may be a challenge. I made several tools to help me do the job efficiently. The big advantages of having Eric do the rebuild is the fresh plating that will preserve the caliper for a long time, and all the new parts that can be so hard to find.
Eric_Shea |
Feb 6 2008, 10:44 AM
Splitting the calipers is the least of your worries. That and putting them back together is a 1 on a 10 scale. This is a myth perpetuated "probably" by the factory. It's been around forever. I don't think they fancied the idea of every Tom, Dick and Harry with an 11mm wrench whacking away at something so vital as... CALIPERS. (IMG:style_emoticons/default/biggrin.gif)
I honestly don't know how you could do a proper rear caliper rebuild w/o splitting them. Frankly, it needs to be done, otherwise; just throw some new dustcovers on the pistons and bolt them back on. The handbrake seal is a cinch... it's just that the kits are (generally) too expensive to warrant the fuss... and, in most cases they're not needed. We have them for $29.00 each which is the best price I've seen Stateside. I'm also not sure any circlip pliers would help. I personally do not have any that will go down into that 33mm hole and function with the adjuster in the way. I'm sure they're out there and can be found but... a very good set of picks is invaluable here (or at least a 90 deg and a straight pick). Zach... you've got my number (on my site). Call me if you need any help. I'll walk you through it. I've been thinking about doing a video for Andy's new video section... (IMG:style_emoticons/default/idea.gif) |
Eric_Shea |
Feb 6 2008, 10:58 AM
Oh... I just noticed you have a 76.
Good luck with that one (IMG:style_emoticons/default/biggrin.gif) Those inner clips are a B-I-T-C-H. Seriously, call me on this and I'll try to walk you through it. These are not the clips with a common circlip hole on the end. I found some "similar" pictures on the web: This is similar to a 1970-1974 inner adjuster clip. It has the holes you can grab and pull with a pick: This is what a 1975-1976 inner ajuster clip looks like (again, not the real thing but similar). You will have a VERY difficult time getting this clip out of the ring it rests in. The ends on the ATE clip are cut at 45 degree angles. You'll need it very clean and dry in there and you'll need two instruments, one to pry up the edge and the other to get behind the clip: |
Matt Meyer |
Feb 6 2008, 11:46 AM
I remembered the only thing that gave me trouble was that circlip and that it really sucked. I have a 75. I just thought it was my lack of skill.
Now that Eric has jogged my memory I think I used a three pics, a small flat screwdriver and about 50 tries to remove and install those little buggers. |
Eric_Shea |
Feb 6 2008, 04:15 PM
QUOTE Now that Eric has jogged my memory I think I used a three pics, a small flat screwdriver and about 50 tries to remove and install those little buggers. Sounds about right... (IMG:style_emoticons/default/lol3.gif) |
sww914 |
Feb 6 2008, 05:47 PM
I like the part when they finally fly out and hit you in the lip.
Everyone asks- cold sore? No, I'm just a shitty mechanic. |
Lo-Fi Version | Time is now: 16th May 2024 - 10:33 AM |
