3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
May 28 2008, 09:06 PM
I also spent some time taking measurements on the engine in my wife's Windstar Ltd. Its the Ford HO 3.8L (200hp) motor. I've always thought this would be a good motor for the 914 because of its decent torque. Since its on my list I wanted to see how it would stack up to the other sixes since its a 90deg.
Here's the fit results: As you can see, even though its 90deg, with the FI intake its just as high as the other 60deg V6's. It is much shorter, though they waste nearly 6 inches for all the accessaries in the front. So far the Subi EG33 is looking the most promising. Its under 400lbs, and the fit is good. It should only require minimal adjustments to make everything work. Now I'm going to get a hold of a local supplier to get more info. So which will it be: ___SHO_____^______EG33__ (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 05:44 AM |
