3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
May 31 2008, 08:29 PM
Well, I got quite a bit done today. I found an awesome paint supply store over in Mesa, AZ. They have everything you need from start to finish. It was mind numbing. They also sell the POR products I was looking for.
I'm using the following: POR-Strip for paint-stripping trunk and areas difficult to sand. POR-Marine-Clean to clean all bare-metal after sanding, prior to treating with POR Metal-Ready. I also picked up the fiberglass clothe and resin/hardener I need to redo the rear flares. First I needed to remove any of the body filler still adjacent to the flares. I haven't found anything to do this cleanly without possibly damaging the flares, so I just used a hand-help chisel and dug out the filler. It worked quite well and was actually faster than trying to use a small diameter wire wheel. You'll notice there is black paint adjacent to the flares. This was under the body filler. They didn't even sand it down to bare metal before adding the flares. I still have some hand sanding to remove the black paint. I ran out of 60-grit paper and need to pick up some more. I was able to get the drivers side done though. More fun ahead . . . |
Lo-Fi Version | Time is now: 17th May 2024 - 02:49 AM |
