3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Jun 23 2008, 08:55 PM
Today I was able to complete the remaining steel support that connects the two engine stands. Once I got the measurements right & cut it, I needed to grind it to fit the two angles used to bolt it to the stands.
It was then welded to the the angle pieces. The angles can then be removed along with the support until the car is up on the stands, then re-attached. It was too hot to do much else. I spend all day in the sun working, so I can only last a few more hours in the garage with no cooling. Then its a cold refreshing shower and I've got my second wind. Wednesday I hope to get the car up on the rotisserie. Can't wait. (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 03:54 PM |
