3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Apr 10 2008, 09:06 PM
This is the first I've been able to get back to the "black hole" since last week. After a couple hours of sanding, cutting, banging, I've cleared out the bulk of the filler to expose the metal around the edges that I have to work with.
It's as I thought. But there is enough there to do either a lap joint or a butt joint, depending on how badly mis-shaped the metal is. I feel a lot better at least knowing whats not behind there anymore. The filler is typically 3/8-1/2in thick! Its also a given that the entire flare will have to be removed from this side. That's the next step. |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:20 PM |
