3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
May 4 2008, 01:37 PM
Its been a while but I haven't been slacking. . .
I stayed with just sanding for the time being, using 60 grit and an electric orbital sander. I'm comfortable with this technique and can accurately control how much I take off. On the flares I'm going down to the gel-coat (if its still called that) - its white in this case. I've drilled out the rivets on the drivers side & removed the tire for better access. I've discovered that they did use some type of bonding material between the flare and the metal - as its apparent from the underside, even though there is a 1 1/2 - 2in overlap of metal. The material appears blackish in color, is very hard, and seems somewhat brittle. I've encountered some areas of this near the bottoms of the flare where they connect to the body panel. So its not going to be just a matter of removing the rivets and filler and pulling off the flare. I'd like to be able to get them off without damaging them. Ideally if this bonding agent is satisfactory, I'd be glad to leave it & the flares in place, and continue with FG cloth and resin on the outer part of the flare/fender. I also came across a combination bonding agent/filler called Dyna-Weld. It would be better to have this material between the flares and metal. But if I can't get them off without breaking them off, it will serve well as an outer filler/bonding agent. |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:04 PM |
