3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
May 4 2008, 01:47 PM
Well, some good news.
I took a break from the back flares and decided to see whats under the front flares. Starting with the right-front, I found some good news. It appears this one was done correctly in that they used FG cloth and resin to bond/blend the outer flare to the body panel. I can still feel rivets underneath, but at least this technique should provide a better basis to work from. If the left-front flare is the same, I'll plan on leaving them in place and just remove all the extra filler. It almost seems like they wanted to change the shape of the flares because all the nice radii are filled with putty to increase the radius. Weird! I also checked on the underside, and here they also used cloth and resin to completely enclose the seam. Sure hope the left-front flare is the same. |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:26 PM |
