3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
May 31 2008, 09:02 PM
Since that final prep before applying the fiberglass took me nearly six hours, minus a short break for the root-beer float my wife brought me, I won't have time today to get to the fiberglass part.
That's a good thing though. What I realized in the process was that there is still a fit problem that I have to address along with sealing up the underside of the flares as well. To get to the underside I'm going to need to build my rotisserie first. I guess I'll work on that during the week. However, I still have a bit of a fitting problem at the bottom of the flares. Here's a couple of pics. Front of flare: Back of flare: The normal line of the body panels should continue through the flare (marked in red), but doesn't. It's almost like they didn't bring the flare up high enough on the top of the fender. But when I look across the fender and the flare from the back, the flare seems to be high enough - and continues the gentle arc. So my thoughts are to cut the flare (front & back) to match the line of the body panels, then buildup a new bottom edge at the same angle as the body panels. I would think this is whats needed so that the valance and outer rocker panel blend correctly as shown in this example (from someone's else's progress thread - I forgot who): I have the FG outer rocker panels - though they are not very good ones. It looks like I'll need to locate the appropriate original style front & rear valances with the flared option to check fit before I do any major FG cutting & repair. In the meantime I can continue getting the two trunks stripped of paint. On with the show . . . |
Lo-Fi Version | Time is now: 2nd May 2024 - 07:57 PM |
