3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Jun 7 2008, 03:48 PM
During the process of removing all the venting in the front, it was necessary to remove the two small 90deg elbows located up underneath the cowl & behind the hood hinges. What was even more surprising is that I saw a round obstruction in each one. At first it looked like the back of a gauge of some kind. What kind of gauge would someone put in there?
With a little effort I was able to turn it around to look at the front, and to my surprise I see a tiny little speaker. Someone put a speaker (probably a tweeter) in each of the fresh air vent tubes. At first all I could do was laugh - (IMG:style_emoticons/default/av-943.gif) Then as I thought about it - it was actually quite creative. I'm not sure how well it would work, but it was certainly an unconventional idea. After we had our good laugh, we continued to remove the windshield wiper assembly. All that was needed was to remove the two 22mm nuts at the wiper blade studs, and cut the rubber standoff plug that holds the center bracket to the firewall. It may be possible to remove the rubber standoff and keep it in tact, but with the dash in place it was difficult to see how it attached to the other side of the firewall. Since the nut was rusted on ours, we chose to cut the rubber and replace the whole piece. |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:39 PM |
