3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Jun 21 2008, 08:28 AM
I spent a couple of evenings this week getting the engine stands ready. I had the pieces already cut, but each one needed grinding to get rid of any variation in the mating edges. The stands are the 1000# variety from Harbor Freight. One is an older style and was taller, so I ended up with two different sized insert pieces.
The inserts do two things. THey raise the housing for the rotating flange to just over 36". Since the base is raised and the front wheels are mounted under the tubing this won't allow full 360deg rotation of the car body. That was intentional on my part. I wanted to keep the body as low as possible. To allow for full rotation, one would need to raise it another 3-4 inches. That would put the center axis at about 40 inches, and the portion of the car aobve the axis would be another 34 inches; giving a total of 74 inches of vertical clearance needed. The second thing the inserts do is negate the 7.33deg angle designed into the vertical 3"x1.5" tubing. I cut the stand tubing 90 degs across its width, then cut the insert piece so that one side has the 7.33 deg cut, and the other is a 90 deg cut. When welded together, this will make the cylindrical housing axis horizontal. Here are the two stands. I'm not going to bother with painting - just keep them functional. |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:24 PM |
