3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Jun 28 2008, 03:04 PM
Today I drained the brake fluid and inspected the disks & calipers. Three of the four disks are under-sized, so I'll be replacing them.
The front calipers are getting replaced with BMW 2002 4-piston calipers, and the backs I'll rebuild and reuse. I'm continuing to strip paint in the rear trunk. I had no idea this would be such a slow process. It takes several applications with 15-20 minute wait between apps. And of course you all know how flat and smooth the trunk is in a 914 - NOT! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) DID I MENTION . . . I found a 3.2L V6 SHO motor to rebuild for $200.00. That's complete from exhaust headers to intake. All I'll need to add is the ECM. The gentlemen that let me come over to measure the SHO engine had one he had pulled from a local junk yard. I'll start with an inspection of the crank and mains, water pump, and rod bearings. If all that looks good I'll proceed with cleanup and the rebuild. I'll get some pics next week when I'm over there. |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:23 PM |
