3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Jul 8 2008, 08:39 PM
Well the fun continues . . .
Engine - Had the block magna-fluxed and found a crack by one of the upper core plug holes. Fortunately Tom had another block, so progress is continuing. I'll get some pics once I get the heads back on. Body - Took some extra time off over the holiday, but I didn't get to use all of it working on the body since I had a side project that came up. I did manage to get the right rear inner part of the fender/flare glassed. I used three layers of material. I'll clean up the edges and cover the whole inner wheel well with some under-body sealer. Pic inside the wheel well. THe black behind the FG is the factory paint. I stripped a couple inches down to metal, but ran into the painted area a little. I also got most of the rubberized seam sealer off in the rear trunk. I tried the torch method, but it still required as much scraping. I found that a good chisel was an excellent way to get under the sealer so I could remove it in bigger chunks. It actually turned out to be faster also. A wire wheel came in handy for some of the small corners - but I found that unlike the scraping (with chisel or paint scraper), which left the factory primer, the wire wheel stripped clear down to the bear metal. Even though this will all get primer, I like the idea of putting new seam sealer on top of the old primer - as the factory did. I'll get some more pics when I get the trunk completely stripped and get some new batteries for the camera. |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:08 PM |
