3D914s 914-6 SHO 3.2L v6, Build Thread - Project for sale. See classifieds |
3d914 |
Mar 30 2008, 06:59 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
OK here goes . . .
I sold my beautiful Ravenna 914/2.0 so I could develop a custom 914 in good conscience. The sweet Ravenna was to stock to cut up and customize, & an admiring buyer wanted to return her to full stock - so it seemed like the perfect match. Now I've found a 74 1.7 that someone has already led down the path of the Dark Side (as the puritans see it), and I'll simply take it the rest of the way. Just as a warning - this is not meant to be a factory GT look alike or anything close. I want to incorporate some of my own ideas and those I like that others have done. In fact at this point its not even going to be a Porsche six. My initial intent is to go with the Ford 3.0L SHO. Plans may change when I get to that point, but that's where I'm headed. It seems reasonable to start with Before pics, so heres a couple of the car before I started any dismantling: |
3d914 |
Jul 26 2008, 04:51 PM
Clay,
I just wanted to do something unusual & non-Porsche. I had three nice cars already that were kept Porsche, but this time I wanted to try something different - hence my choice to go SHO. Speaking of which - I worked on the valve covers & intake manifold today. The valve covers just needed minor cleaning and light sanding. They have a coating on them (I don't think it anodizing), so I need to find out if this can be painted on or not. Started to disassemble the intake manifold. Here's the beast with most attachments. I need to remove several bosses that I will not be using and will help reduce the length for a better fit. The first to go is the DIS flange. To remove it I first cut off large sections top & bottom, then started to grind and file down close to the desired shape. I continued to rough the shape with a file, then did some sanding with 60 & 100 grit. The hole will get welded in and then I will finish it all off. But there are several other smaller flanges that need to come off also. I like aluminum . . . |
Lo-Fi Version | Time is now: 2nd May 2024 - 08:08 PM |
