The Project Anklebiter Build Thread., 8/29 Lid latches and glamor shots... |
plymouth37 |
Jun 9 2008, 01:08 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
scotty b |
Jun 10 2008, 06:38 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
The roof....Carson Top
Make a buck from wood, PVC pipe whatever you think would be better suited to get the line you want, Then do the panty hose fiberglass trick. Viola you have a removeable top. Glass in some attachment hardware. Tkae a look at the quick top kits made for Jeeps for the front latches and maybe some sort of vertical pin setup in the rear. Obviously the pins would have to have some sort of tension put on them to seal and protect (IMG:style_emoticons/default/idea.gif) theraded rod would work but who wants to bolt and unbolt the F-in top everytime it rains. Peanut gallery ??? |
lotus_65 |
Jun 11 2008, 05:10 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
The roof....Carson Top Make a buck from wood, PVC pipe whatever you think would be better suited to get the line you want, Then do the panty hose fiberglass trick. Viola you have a removeable top. Glass in some attachment hardware. Tkae a look at the quick top kits made for Jeeps for the front latches and maybe some sort of vertical pin setup in the rear. Obviously the pins would have to have some sort of tension put on them to seal and protect (IMG:style_emoticons/default/idea.gif) theraded rod would work but who wants to bolt and unbolt the F-in top everytime it rains. Peanut gallery ??? sure. i would do a Campi style quick-release setup. schweet ride |
Lo-Fi Version | Time is now: 26th April 2024 - 10:01 PM |
