rear rotor screws and decklid t-bar blues |
melnyk |
Jul 31 2008, 09:06 PM
Member Group: Members Posts: 104 Joined: 26-July 08 From: wilkes-barre Member No.: 9,359 Region Association: None |
does any one know the proper size and pitch of the rotor screws? i gnarled these up pretty good taking them off (even with heat an impact tool and tons of pb blaster) anyone with this info would be awesome. also i need to change the wheels on my rear deck i have the replacements but my shop manual tells me i need a special tool for the t-bars. now i know one of you animals did this with out it, so tell me your secret.
Jul 31 2008, 09:10 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
does any one know the proper size and pitch of the rotor screws? i gnarled these up pretty good taking them off (even with heat an impact tool and tons of pb blaster) anyone with this info would be awesome. also i need to change the wheels on my rear deck i have the replacements but my shop manual tells me i need a special tool for the t-bars. now i know one of you animals did this with out it, so tell me your secret. No idea on the screws, sorry. go to PMBperformance.com Ask Eric Shea...he has them on stock. The torsion bars....tricky little buggers. If all you are doing it replacing the roller I will tell you what I do. FIRST...the spring is under a shitload of tension...it can get away from you so keep your fingers away from the area behind the spring...its enough to snap fingers in half. I use a deep 10mm or 11mm socket on a long extension... Slip it over the rod right at the roller.. Bend it down and slide the socket deeper as fast as you can. Once you have the socket all the way on there, you can just push it down and replace the roller...just watch the fingers...its scary. Rich |
Jul 31 2008, 09:14 PM
does any one know the proper size and pitch of the rotor screws? i gnarled these up pretty good taking them off (even with heat an impact tool and tons of pb blaster) anyone with this info would be awesome. also i need to change the wheels on my rear deck i have the replacements but my shop manual tells me i need a special tool for the t-bars. now i know one of you animals did this with out it, so tell me your secret. - rotor screws: don't know the thread/pitch but i had a batch of "replacement" screws that was made of some kind of soft metal and the hex slots didn't last. one removal and they were useless. i went to my local porsche dismanteler and got a handful of original setscrews for $1, they work much better ... - torsion spring removal: http://www.914world.com/bbs2/index.php?showtopic=39320 (IMG:style_emoticons/default/bye1.gif) Andy |
MrKona |
Jul 31 2008, 09:21 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
I'm away from home and garage at the moment... but from memory, aren't the rotor flat head screws just an M6 metric thread?
melnyk |
Jul 31 2008, 09:22 PM
MrKona |
Jul 31 2008, 09:27 PM
These screws, right?
Attached thumbnail(s) |
melnyk |
Jul 31 2008, 09:31 PM
Eric_Shea |
Jul 31 2008, 11:41 PM
neo914-6 |
Aug 1 2008, 02:35 AM
QUOTE Metric 18-8 SS Flat Head Phil Machine Screw M6 Size, 10mm Length, 1mm Pitch In stock at $9.08 per Pack This product is sold in Packs of 50 Packs of 50 If you buy a pack I'll buy 5 from you. Someone told me you can buy low quantities but it's not indicated on the online form... (IMG:style_emoticons/default/confused24.gif) |
914Sixer |
Aug 1 2008, 07:09 AM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Readily available at Home Depot, Lowes, hardware stores, Flaps. Usually in a 2 pack for less than a $1.
rhodyguy |
Aug 1 2008, 08:37 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the socket extension trick is easy. no special tools needed. a deep 1/4"drive socket is the best to use due the thiner walls. prop the the rear trunk open with a stick first. this takes quite a bit of the pressure off of the springs/hinges. if you're going to stay with the springs replace the roller wheels with the bronze versions.
k |
davep |
Aug 1 2008, 08:49 AM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
They are M6 x 1.0 pitch, and are similar to many other cars. My POS Honda Civic uses the same thing. HOWEVER, in most cases the heads are too large to fit in the recess of the rotor. That means drilling the rotor to suit, or grinding the heads of the screws. Be sure to use anti-sieze compound on the threads; they can be nearly impossible to remove later if you don't.
BTW, the original screws were slot heads. |
Eric_Shea |
Aug 1 2008, 09:46 AM
If'n ya'll don't have an "Impact Driver" set, run off to your local Craftsman reseller and get one. That and a MAPP torch are the only way to consistently and successfully remove these puppies.
http://www.sears.com/shc/s/p_10153_12605_0...20070921x00003a I'd also recommend getting the phillips version as there is a bit more surface area for the fastener to engage. As Mark says... these are pretty common items at Lowes and/or Home Depot. |
melnyk |
Aug 1 2008, 06:23 PM
If'n ya'll don't have an "Impact Driver" set, run off to your local Craftsman reseller and get one. That and a MAPP torch are the only way to consistently and successfully remove these puppies. http://www.sears.com/shc/s/p_10153_12605_0...20070921x00003a I'd also recommend getting the phillips version as there is a bit more surface area for the fastener to engage. As Mark says... these are pretty common items at Lowes and/or Home Depot. yeah i was using my big ass mapp setup (im an HVAC tech by trade) and an impact driver and still fukked up the lefts the rights went easier. i found stainless versions of these screws at my local hardware store today. sweet muffins! |
ArtechnikA |
Aug 2 2008, 08:11 AM
'course you realize that those screws are basically just used to keep the disks from falling off while the car is on the assembly line, before the roadwheels are mounted... And maybe to keep the disk from shifting on the hub during roadwheel replacement, but I have never experienced that phenomonon...
With the lug bolts in place, the disk isn't going anywhere, and if that were their purpose they'd need to be way bigger than M6... |
Eric_Shea |
Aug 2 2008, 12:04 PM
Those screws are used to properly set the handbrake on both the 911 and the 914. While this can be done with a couple open end nuts; the practical application must have the rotor secure to the hub to properly set either the 914 calipers venting clearance or the star mechanisms on the 911 drum brake. Neither of which can be accomplished with the wheel on the car.
ArtechnikA |
Aug 2 2008, 01:25 PM
Aug 2 2008, 11:24 PM
And maybe to keep the disk from shifting on the hub during roadwheel replacement, but I have never experienced that phenomonon... I have. Enough to have the rotor hit the caliper in one spot every rotation ... But then again, i currently have the exact same problem on one wheel, if i actually tighten those damn screws down! seems like either the hub or th rotor is out of round. I have to back off on the screws just a bit to get the rotor to be where it should be ... (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 21st May 2024 - 05:41 AM |
