QUOTE(melnyk @ Jul 31 2008, 11:06 PM)
does any one know the proper size and pitch of the rotor screws? i gnarled these up pretty good taking them off (even with heat an impact tool and tons of pb blaster) anyone with this info would be awesome. also i need to change the wheels on my rear deck i have the replacements but my shop manual tells me i need a special tool for the t-bars. now i know one of you animals did this with out it, so tell me your secret.
No idea on the screws, sorry.
go to PMBperformance.com
Ask Eric Shea...he has them on stock.
The torsion bars....tricky little buggers.
If all you are doing it replacing the roller I will tell you what I do.
FIRST...the spring is under a shitload of tension...it can get away from you so keep your fingers away from the area behind the spring...its enough to snap fingers in half.
I use a deep 10mm or 11mm socket on a long extension...
Slip it over the rod right at the roller..
Bend it down and slide the socket deeper as fast as you can.
Once you have the socket all the way on there, you can just push it down and replace the roller...just watch the fingers...its scary.
Rich
