fog light > driving light, installation |
jfort |
Feb 6 2004, 08:58 AM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
just to have a record on this board, i am in the process of installing driving lights where the fog lights go. i got some well-prepared grills from korjo. the lights mentioned in the attachment, made by Pilot, are indeed available from Auto Zone. About $45. I had the brackets made at a local shop. I'll let you know how it turns out.
http://members.rennlist.com/demick/lights.html |
jfort |
Mar 15 2004, 02:18 PM
got the Pilot driving lights installed, finally. did it without removing the bumper or valence. I started a hex (allen) bolt and then slid the mounting bracket (with the bottom cut out) over the bolt. then i was able to tighten it with a balled-end allen wrench. got a fog light switch. now just need to do the wiring. my goal is to have headlights down on the first switch stop. i also want to be able to "flash" the driving lights with the turn signal arm. also installed Hella 7" H4's. that should do it.
Lo-Fi Version | Time is now: 18th May 2024 - 10:04 PM |
