Anything break on your car latley?, Vent Here |
sww914 |
Nov 1 2008, 12:37 PM
Rear window rattles like crazy over every bump. My fresh duct tape windshield molding came off. I'm waiting to fix the loose glass until after I paint it. I have the paint, I just don't have the time.
My clutch cable tube broke at the firewall, I fixed it and the car shifts a hell of a lot better when the clutch fully disengages. (IMG:style_emoticons/default/smile.gif) My door buzzer only works after I take the key out, I gotta find that little POS and pull it out or shoot it with a .45. Either way, I'll be happy to never hear it's anemic whine ever again. |
Gint |
Nov 1 2008, 12:59 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Now that you mention it... that stupid tape along the bottom of ny rear window is loose. It buzzes when the wind buffets it. Driving me bonkers.
Nov 1 2008, 01:55 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
YOU have a cup holder??? Two actually. I got one of them generic center trays from FLAPS with two cup holders. Fits perfectly between the stock seats. It's a must for any road trip, and i have done two of those since i got that little bump in displacement ... (IMG:style_emoticons/default/smile.gif) Andy |
Root_Werks |
Nov 1 2008, 01:59 PM
Village Idiot Group: Members Posts: 8,334 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Never driven the one I have yet. Give me some time, I'll break plenty on it. (IMG:style_emoticons/default/biggrin.gif)
dlee6204 |
Nov 1 2008, 03:37 PM
Mountain914 |
Nov 2 2008, 10:29 AM
Too much time in thin air! Group: Members Posts: 367 Joined: 22-May 03 From: Conifer, CO Member No.: 725 Region Association: Rocky Mountains |
October 26th, nice drive in the mountains, figured last drive before tucking it away for the winter. Driving up a hill and it starts cutting out (IMG:style_emoticons/default/huh.gif) and dies.
Pull it over and thinking dead fuel pump. Call AAA and have it towed (the ultimate embarassment) and I'll just worry about it in the spring. (sigh). |
jsayre914 |
Nov 2 2008, 12:54 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Call AAA and have it towed (the ultimate embarassment) Dont be embarassed... My last 914 did not have a fuel guage, one morning I was driving tward the gas station to fuel up and sure as shit died 9 blocks or so from the station, 5 min drive or 20 min walk back to the house to get the can and 45 min walk to station plus 25 min walk back to car. I decided to call AAA and they gave me a 5 min piggy back to drop me at the pump. (IMG:style_emoticons/default/hide.gif) |
PlaysWithCars |
Nov 2 2008, 01:57 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Well, let's see... here's the saga with the new car.
Transmission was noisy but functional except for the occasional clunk when coasting. Decided to change the oil and run it until it died. When draining the oil I heard "clink, clunk" as pieces fell out into the drain pan. Big roller bearings. Okay, guess that transmission is done. Put a good used transmission in the car and took it to the local PCA autocross to shake down other issues. Broke a transmission mount which broke the ear off of the "new" transmission and tore one of the oil lines going to the oil tank. Hmmm so far the car isn't living up to expectations. Keeping a stiff upper lip though I tore down the original transmission and took off the rear housing to put on the "new" transmission. While the car was down waiting for gaskets I tore into the dash to figure out why none of the idiot lights or tach were working. Still don't know why the tack isn't working but found all of the idiot lights were disconnected. Looks like the PO had an aftermarket gauge package installed at one point and bypassed the idiot lights but the gauges are no longer in the car so it seemed prudent to hook up the idiot lights again. Okay, fast forward 2 weeks: idiot lights hooked up, rear transmission cover replaced, new transmission mounts installed, new oil line installed, ready for a test drive. Start up the car and the newly hooked up oil pressure idiot light is flickering on and off at idle, raise the RPM and it goes off. Once the car is warm though the light stays off. Head scratcher, backwards from normal. Usually its when the motor is warm that you get low oil pressure at idle. Fast forward 2 more weeks: installed a mechanical oil pressure gauge to make sure the problem is real and not just a faulty sending unit. Yep, its real. Condition is degrading too. Started the car yesterday, no oil pressure for 5 secs, then built up to 70psi at idle for 15 sec, then dropped to zero. Shut down and restarted multiple times, no oil pressure. Grrr... (IMG:style_emoticons/default/headbang.gif) I guess the old addage is true: buyer beware. |
MoveQik |
Nov 2 2008, 06:36 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
WTF happened there? Don't know yet. I am too disgruntled to find out. As I turned on to my cul-de-sac coming home from RRC I heard a sudden & loud tapping noise from the engine. I looked back and saw a boat load of smoke coming from the exhaust. I tapped the gas enough to get up the curb and shut it down. I haven't started it since. Now, my once dry as a bone underside is also covered in oil and the garage floor has about 2 quarts neatly spread all over it. (IMG:style_emoticons/default/dry.gif) I'll have it back on the road for Route 66. That is my goal. Who knows....maybe it'll be a 3.4 by then. (IMG:style_emoticons/default/biggrin.gif) |
jsayre914 |
May 4 2009, 02:40 PM
(IMG:style_emoticons/default/smash.gif) I declare this thread will never die (IMG:style_emoticons/default/happy11.gif)
Driving home last night, i got up to speed on the freeway, just about 4200 rpm and i hear... BAM !@ The rain + speed + 30years = the bueatiful metal trim around the top/ side windshield frame blows off the car into the dark night. (IMG:style_emoticons/default/sad.gif) it smacked the roof really hard just befor it flew away. a moment of silence for the missing part. i will have a brief search party on the way home tonight. |
derekdenman |
May 4 2009, 02:54 PM
Newbie Group: Members Posts: 33 Joined: 29-June 07 From: Mckinney, Tx Member No.: 7,852 |
My 914 has become my primary driver again because my Toyota Corolla brokeā¦ If that counts.
Toyota has 312K on it and the igniter within the distributor stopped working. I have to replace the whole distributor to fix it and that is a cool $300. I only paid $500 for the car. On top of that it broke down in Downtown (southeast) Dallas, which is a very rough area, at 2 am last Thursday. Then the next day I found out that I had gotten evicted because my roommate took my rent money and skipped town. The plus side is that now I have a perfect excuse to drive the 914 every day. |
VaccaRabite |
May 4 2009, 03:37 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The rain + speed + 30years = the bueatiful metal trim around the top/ side windshield frame blows off the car into the dark night. (IMG:style_emoticons/default/sad.gif) it smacked the roof really hard just befor it flew away. a moment of silence for the missing part. i will have a brief search party on the way home tonight. My old trim is in the garage somewhere. Yours if you want it. Has to be in better shape then yours after taking flying lessons. QUOTE Okay, fast forward 2 weeks: idiot lights hooked up, rear transmission cover replaced, new transmission mounts installed, new oil line installed, ready for a test drive. Start up the car and the newly hooked up oil pressure idiot light is flickering on and off at idle, raise the RPM and it goes off. Once the car is warm though the light stays off. Head scratcher, backwards from normal. Usually its when the motor is warm that you get low oil pressure at idle. Fast forward 2 more weeks: installed a mechanical oil pressure gauge to make sure the problem is real and not just a faulty sending unit. Yep, its real. Condition is degrading too. Started the car yesterday, no oil pressure for 5 secs, then built up to 70psi at idle for 15 sec, then dropped to zero. Shut down and restarted multiple times, no oil pressure. What was your problem? My car has the exact same symptoms. Zach |
jsayre914 |
Jul 27 2009, 02:41 PM
update:
Fixed all transmission problems (thanks Evil) and the exhaust wont go back on, one stud dropped out of the head and left a crater the size of the moon. po filled the void with some kinda putty. Now have to pull the head, meanwhile the passenger side shoulder bolt gave up last night, i got a kit from j-west (i think) and replaced the driver side few months back. The entire pivot on the passenger side was no longer connected to the car. And then to top it off.... while i was drilling the jwest trunk hinge, i placed the corded drill on top of the car for a second, only to trip on the cord and have it wack the top of the passenger door with the drill bit. (IMG:style_emoticons/default/sad.gif) one more ding This thread will continue F O R E V E R |
Lo-Fi Version | Time is now: 7th June 2024 - 08:44 AM |
