Looking for an engine exhaust gas analyzer |
Joe Bob |
Feb 11 2004, 07:22 PM
Anyone know of one that has been decommisioned by a gas station due to the new smog regs?
Malmz |
Feb 11 2004, 07:40 PM
CSOBOSC founding member Group: Benefactors Posts: 489 Joined: 22-April 03 From: So. Cal Member No.: 602 |
I think there is an old school one at a parts store in Woodland Hills. Big-arse unit that would be cool in your workshop. If I remember correctly, it has a tach and dwell on it too. Call Affordable Auto Parts in Woodland Hills to see if it's still there.
sm |
TimT |
Feb 11 2004, 07:45 PM
DuckRyder |
Feb 11 2004, 07:53 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
These show up on E-Bay pretty regularly too.
seanery |
Feb 11 2004, 08:35 PM
My guy in Marina Del Rey may have one. I've never seen it used and they are moving his shop in a couple months.
Precision Tech ask for Alex 310-822-4566. Tell him I (Sean Lee) told you that he may have one. |
Joe Bob |
Feb 11 2004, 08:39 PM
Thanks...
ArtechnikA |
Feb 11 2004, 08:47 PM
i have a Gunson - it just does CO, but since the MFI is spec'd using %CO, it works great. the wideband stuff that measures A/F is good for what it does but there isn't as direct a correlation between A/F and CO as you might think. if you need HC and NOx, it won't help you, tho.
nowadays you pretty much need CO, HC, NOx and O2 - and i've heard of 5-gas analyzers and i can't think what the 5th gas would be... CO2 probably ... |
Joe Bob |
Feb 11 2004, 08:50 PM
I just started calling a few gas stations in my area to see if the obsolete Bear analyzers are still in the back room. My 3.6 was a little high at idle for HC....I'm gonna do a valve adjust, repalce caps and rotors/plugs and fiddle with the A/F to get it dialed in before I have to go to the referee.
Lo-Fi Version | Time is now: 16th May 2024 - 11:05 PM |
