Front Sway Bar U-Tab Location |
bcheney |
Nov 23 2008, 07:16 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Can anyone tell me if these Weltmeiter front sway bar tabs look like they are mounted in the right location? I am having some problem getting these to attach correctly.
Thanks, Attached thumbnail(s) |
bcheney |
Nov 23 2008, 07:17 PM
jcd914 |
Nov 23 2008, 07:31 PM
Your pics are to dark for my old eye to make out all the detail but I can tell the U-tabs are welded on wrong. The tabs should be turned 90degrees so the bolt slides in front to rear parallel to the center line of the car.
I also don't recall the tabs being so close to the ball joint. If I can get to the arms in my garage I will measure the location of them. Smart Racing makes some clamp on drop link brackets that provide a better location than the Automotion or factory tabs. Jim |
Richard Casto |
Nov 23 2008, 09:32 PM
Yes, they are welded on wrong. As mentioned above they should be rotated 90 deg.
See post #5 in this ancient thread regarding how far back from ball joint. (Someone please let me know if that is wrong as I am about to weld these tabs on using this info)... http://www.914world.com/bbs2/index.php?showtopic=7223 |
rjames |
Nov 24 2008, 11:47 AM
I'm made of metal Group: Members Posts: 3,930 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Here ya go:
bcheney |
Nov 24 2008, 06:04 PM
Thanks guys. I got the tabs off today..now I just got get'em welded back on in the right location per the diagram!!
Lo-Fi Version | Time is now: 14th May 2024 - 05:03 AM |
