jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,850 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
My '14 lived a hard life (before I bought it, of course) so its got alot of floorpan rust holes. I plan on weldinng in new pans, but I want them to last. What kind of rust preventative stuff have you guys used. I'd like personal testimonies as well as brands to steer away from. I know lots guys have used POR 15, has anyone used anything else. (IMG:style_emoticons/default/beerchug.gif)
swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
Why not just a fresh coat of primer and paint? Seems to me like that's optimal. I'm currently pulling up the tar sound proofing to deal with a very small amount of rust, but I'm going to just paint it.
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
optimal?.... get to bare metal apply a good zinc primer... top it with a good base and top coat..
and then maintain it |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
The best rust preventative is you. If you realize what causes the rust (problem areas) and watch them closely then there won't be any problems. The factory made attempts, but factory seam sealer is always hiding some rust. No protection is 100%. You will never completely get away from rust. Our cars aren't rusting away because of poor prep. Floor pans rust away because of leaking seals, mostly the rear window. I have a loose rear window in my green car. I still haven't fixed it, and that's what causes rust. Not the loose window per se, me not fixing it causes rust. The longs rust out because stuff gets trapped in there and they need to be pulled and cleaned. The hell hole exists because batteries leak. Everyone has an Optima or Orbital in there car by now, right? The rear trunk leaks because it doesn't seal, drill holes in the pan to let it drain. Or cars WILL completely FILL the rear trunk if they aren't allowed to drain. I'd rather have a few 1/8" holes in my trunk than rust. So put POR 15 (or something else) on your car as a safetly measure and then take care of it. If you pay attention to the problem areas and your restored car still rusts out then I'll pay for the next one.
Rant Over. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/mueba.gif) |
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
(IMG:style_emoticons/default/agree.gif) Mark, you hit the nail on the head. (IMG:style_emoticons/default/agree.gif)
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
So I guess dipping the car in sea water and parking it a jungle doesn't work? (IMG:style_emoticons/default/lol3.gif)
Lo-Fi Version | Time is now: 9th July 2025 - 01:55 PM |
