Subaru WRX 23 914 Progress Thread in AZ (252 HP at the wheels!)), The results are in! 252 HP and 262 torque!! (read last pag |
budman5201 |
May 26 2009, 12:04 AM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
Your project is really coming along. Great job! I know what you mean about secrecy and Renegade. I visited his shop in Vegas a couple of months ago and was amazed at some of the projects in his shop, but he holds his cards pretty close to his vest. He is also pretty proud of his work and insistent that he has the optimal solution, basically poo-pooing some of my ideas. But I really enjoyed the tour. Did you consider reversing your intake manifold? See http://www.914world.com/bbs2/index.php?sho...83031&st=60 for details on what I'm doing for my Suby-powered 914... Geoff Well i am keeping A/C because i live in Arizona and its HOT here. So reversing the intake would mean losing my Compressor. I tried it and it works but no compressor. (IMG:style_emoticons/default/smile.gif) Check out this pic. This is a MOD to that same exact intake, it points straight up. Worked great on my last NA conversion. I still have it. Its unbelievable how much room i had underneath the intake when i MOdded it. Yeah keep me informed of your progress too...... I believe that i do NOT have the best solution, i am always open to input. Renegade does have that attitude though, which in my opinion kinda sucks. Someones engineering might be better, thats always a possibility (IMG:style_emoticons/default/smile.gif) Attached image(s) |
budman5201 |
May 26 2009, 12:11 AM
Anyone have a LOW valance like this that i can hack up? I need to "blend" it around my heat exchanger in front. Think i am going below the opening in front. I want Ice cold A/C.
Maybe someone had a nice one and hit a curb so its cracked in the middle. I'll take it! Attached image(s) |
charliew |
May 26 2009, 12:18 AM
I have 916 front and rear bumpers that I will try to make look decent. Also if you ever go to the phase 2 style heads with the different intake port bolt pattern the 06 2.5i intake is a higher/bigger intake. I'm going to get one and see how it fits rotated.
budman5201 |
May 26 2009, 09:16 PM
We Have FINAL Heat Exchanger up front Position. That should definately allow a ton of air to radiator. I split it. Half of the heat exchanger air goes through the radiator and half goes underneath the car. (that way i wont bump it on curbs either)
Woo hoo! Thats one thats been in my brain forever to how it would look. Now to tear it down and start welding reinforcements. (IMG:style_emoticons/default/welder.gif) Anyone have a Billet 350Z grill? (IMG:style_emoticons/default/smile.gif) Attached image(s) |
budman5201 |
Jun 8 2009, 07:59 PM
Okay Air/air intercooler Converted to Heat exchanger DONE! Whew, i might be good at steel Tig welding, but man i need more practice on Aluminum. (not good yet)
budman5201 |
Jun 8 2009, 08:01 PM
Mounted
budman5201 |
Jun 8 2009, 08:02 PM
another
budman5201 |
Jun 10 2009, 05:40 PM
Subaru Fuel Rail vs.....
budman5201 |
Jun 10 2009, 05:41 PM
My Fuel Rail...much Simpler and serviceable if needed. Bigger diameter lines also for more flow if needed.
charliew |
Jun 10 2009, 10:36 PM
Not sure what you are planning on the filters. The plastic won't handle 45psi. Also the deal would be to run the fuel rails in parallel so one side doesn't see more volume/pressure than the other. Parallel feed to each rail then the rails go back together to the fuel pressure regulator then the return from the regulator to the tank or a surge tank then the tank. Hose clamps are a little shakey with high pressure fuel lines.
plymouth37 |
Jun 10 2009, 10:49 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
Oh my God you posted a photograph of the Renegade cradle! The Police are on their way! The Four Horsemen of the apocalypse have been released and a scourge of locusts are descending on your garage as we speak!
But seriously, keep up the good work... |
3d914 |
Jun 10 2009, 11:17 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Budman,
Outstanding work as usual! |
budman5201 |
Jun 11 2009, 12:49 AM
Not sure what you are planning on the filters. The plastic won't handle 45psi. Also the deal would be to run the fuel rails in parallel so one side doesn't see more volume/pressure than the other. Parallel feed to each rail then the rails go back together to the fuel pressure regulator then the return from the regulator to the tank or a surge tank then the tank. Hose clamps are a little shakey with high pressure fuel lines. the plastic filter is before the fuel pump (low pressure) and the metal one after the fuel pump. I know about running the fuel lines in parallel, but this is definately the cheaper way. I am running it the same way as stock because the stock fuel regulator actually slides into fuel injector rail and cant be used in that parallel setup without buying a whole new fuel regulator. But an easy change in the future since i have all an6 fittings now. (IMG:style_emoticons/default/aktion035.gif) |
MoveQik |
Jun 11 2009, 01:10 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
When will all of us AZ folks get to see this thing in person?? (IMG:style_emoticons/default/beerchug.gif)
budman5201 |
Jun 11 2009, 02:37 AM
When will all of us AZ folks get to see this thing in person?? (IMG:style_emoticons/default/beerchug.gif) About 3 weeks. Got a little delayed, because i was rebuilding a jetski motor. Where in scottsdale are you located? I am down here off of Germann and Alma School next to the 101 |
MoveQik |
Jun 11 2009, 09:42 AM
When will all of us AZ folks get to see this thing in person?? (IMG:style_emoticons/default/beerchug.gif) About 3 weeks. Got a little delayed, because i was rebuilding a jetski motor. Where in scottsdale are you located? I am down here off of Germann and Alma School next to the 101 Cactus & 101 (IMG:style_emoticons/default/biggrin.gif) |
WaideS |
Jun 11 2009, 10:14 AM
Has been Group: Members Posts: 220 Joined: 25-January 06 From: Valley of the Sun Member No.: 5,475 Region Association: None |
yeah, yeah
Count me in on the unveiling..... |
budman5201 |
Jun 15 2009, 01:04 AM
New Revolutions!!
budman5201 |
Jun 15 2009, 01:06 AM
Zaney |
Jun 15 2009, 10:31 AM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
They look great!
What size are they and what tires did you mount? (IMG:style_emoticons/default/beerchug.gif) Nate |
Lo-Fi Version | Time is now: 28th May 2024 - 01:22 PM |
