| VaccaRabite |
May 27 2009, 11:26 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,901 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
The 914 rears do not self adjust at all, so you need to re-adjust them every 6 months or [...] Zach If they are not meant to adjust, please explain the purpose of all the parts inside other than the screw and locknut and why they are not directly connected to the piston. Read this, and find out. (IMG:style_emoticons/default/smile.gif) Eric's Rear Brake Venting Post The above thread should be in Classics, BTW. Zach |
| mskala |
May 27 2009, 12:13 PM
R ![]() ![]() ![]() Group: Members Posts: 1,958 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
If they are not meant to adjust, please explain the purpose of all the parts inside other than the screw and locknut and why they are not directly connected to the piston. Read this, and find out. (IMG:style_emoticons/default/smile.gif) Eric's Rear Brake Venting Post Zach Okay, first of all, right in that thread, The Cap'n specifically states he's never had to re-set the venting clearance between pad changes. Second of all, if they were not designed to be self-adjusting, is there a spot in the Owner's Manual that says to adjust rear venting clearance as part of periodic maintenance and not just when putting in new pads? Not that I'm saying they all work, or the design works well, but I believe that every time the brakes are applied there is small force that is supposed to make the mechanism move outward by rotating on the screw. But it's been many years since I've had the parts out. |
| Cap'n Krusty |
May 27 2009, 05:03 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
i don't think so... I believe the clearance will track with the pad wear. Nope. At least, that is not my understanding as to how it works. The 914 rears do not self adjust at all, so you need to re-adjust them every 6 months or at the start of every driving season. As the pads wear, the calipers have to push them farther to get to the rotor, until they just don't work at all. Zach That's NOT true. They self adjust as the pads wear. You DO NOT have to periodically readjust them. The Cap'n |
Lo-Fi Version | Time is now: 12th August 2026 - 05:26 AM |
