914-6 flywheels? |
914-6 flywheels? |
bhfast |
Apr 1 2003, 04:08 PM
live it loud, balls out Group: Members Posts: 83 Joined: 30-December 02 From: Chandler, AZ/Daytona Beach, FL Member No.: 48 Region Association: Southwest Region |
correct me if I am wrong, but you can OE 914-6 or early 911(w/901) flywheels with engines from 2.0-2.7. I've noticed a wide range of prices from different supliers. Also does any one have a clutch recommendation for a six conv.
Brian (IMG:style_emoticons/default/cool.gif) |
joea9146 |
Apr 1 2003, 04:14 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
The early 911 flywheel will work up to a 2.7..... if you go 3.0 or above you need a special flywheel. I got my Flywheel and clutch package for KEP Kennedy Enginered
Products. I have a 3.0 with the satge 1 clutch and 228mm flywheel. I believe many other Vendors use KEP as there suppliers.... |
TimT |
Apr 1 2003, 04:40 PM
If you can get one use one of these, a 906 flywheel. Dunno how much they cost or if they are even available but they appear light!!! The Kennedy cluthes are great, also centerforce are good replacements, and the Sachs is too
echocanyons |
Apr 1 2003, 08:07 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Wevos 915 flywheel/clutch looks really light (IMG:http://wevo.com/flywheelandclutch.jpg)
not sure of the street applications though |
TimT |
Apr 1 2003, 08:34 PM
the Wevo is just an on off switch. Dont even thinik about holding your car on a hill with the left foot, and if you trailer your car push or winch it onto the trailer
Brad Roberts |
Apr 4 2003, 02:13 AM
Actually.. WEVO is working on a street setup using that flywheel and clutch setup.
B |
Lo-Fi Version | Time is now: 20th May 2024 - 04:00 AM |
