QUOTE(naro914 @ Nov 9 2009, 09:14 PM)
OK, so it's not winter yet, but my season starts early next year so I need to get a lot of stuff done soon. Last year, I had a LOOOONG list. I finished most of it, but here is the 2009/2010 winter list...
HUEY Projects:
- Install Tilton Brake Bias adjuster (project from last year)
- install blade fuse panel (from last year)
- re-do door panels
- re-do dash face
- new plug wires - blue?
- carpeting (from last year) with soundproofing on fire wall
- relocate battery
- new muffler
- new clutch/pressure plate
- limited slip???
- new suspension - maybe Koni adjustable or something
- figure out how to make 914-6/911 left hand key ignition
- fix an old/new oil leak that is driving me crazy
- fix weird ignition problem
- maybe do megasquirt EFI....not sure yet...maybe just PMO carbs
PAPA SMURF Projects:
- Install new Wevo engine mounts
- new clutch/pp/lwfw
- limited slip
- install hood pins
- scrape tar off floor/paint pass compartment
- make new custom wiring harness
- fix fuel guage/sending unit
- fix temp guage/sending unit
- repair fiberglass from agricutural excursion of 2008 at VIR (from last year)
- rear brake pads
most of the important stuff with Papa Smurf will be done this week before our last event of the year (VIR the weekend before Thanksgiving)
Thats it for me, I think...
Anyone else?
Hi Guys,
I keep on saying I have to get pictures on here and haven't done so yet. I live here in Dartmouth, Nova Scotia, Canada and am just a few hours away from Ian Stott, Moncton New Brunswick (haven't met Ian yet either) who posts here as well.
I am restoring / building my 74 914. I want to run it on the street but at the same time run it for track days, DE Events (member of Acadia Region PCA) and generally drive as much as possible from May to November / December each year.
You guys have given me all kinds of ideas but, the key for now is to get the car finally back on the street.
Projects for this Winter Include:
Engman Long Reinforcements - Received, thanks Marc
Order / Install Hood Shocks front and rear
Order / Install Driver's side floor panel - mine is not all that bad but I am in here and I really want to maximize the benefit of Marc's Sill panels.
Order / Install Fusebox form Engman - clean up that side of things
Reassemble Heater box and all pipes at back.
Finish brake brake lines and plumb system re fluid etc.
Figure out what I am going to do re Park Brake - need to run new lines through new rear fire wall panel - person who installed did not allow for holes to go through but, easily fixed once I get at it.
Reinstall Shift rod under car
Install Clutch and Throttle cables
Install Carbs adn sync (should be fun)
Order / Install MSD Box
Install Exhaust
Test, Tune, Drive
Much thanks to you guys for all of your information and the fantastic work that many of you have done on your cars. I am busy ordering parts for the Winter with the thought that I can get a little done this winter (no heated garage and temperatures get down to -18 - -20ish on a regular basis in winter - not so bad but it is a damp cold as we are on the coast as well) re longs, floor, fuse panel and some cleaning up of wiring especially in the front trunk area.
Regards,
Grant
