Actually, the front covers came off pretty easily - both sides. I've really never had any significant problems with corrosion on my 914. Nothing I have worked on thus far has been "welded" closed.
Anyway, the rear calipers are on and adjusted. Once I understood that I needed to transfer the inner adjusters to the new calipers, everything went pretty smoothly. Of course it was a PIA to replace the flexibe lines for the rear brakes, but nothing I wasn't expecting.
I plan on installing the Porterfields on the front tomorrow. Then the front brake adjustments and it's time to bleed the lines with ATE gold brake fluid (I alternate between the blue and gold so that I am assured the fluid has been completely replaced).
The new calipers look pretty nice (I still wish they were red
). And I carefully had read your adjustment documents and I adjusted the pads to .006.
OK, settle down, I was just kidding
. I adjusted them to your specified .004.
I'm hoping for some dry weather on Monday (it rained again this afernoon) so that I can seat the pads correctly.
My thanks to Eric, Conehead and Tirebottom for their assistance!
Eric Read
