QUOTE(Jake Raby @ Apr 10 2011, 08:00 AM)
These frequent adjustments should not be necessary. What brand of valves and etc did you use? Were the valve seats changed from OEM?
The frequency is mainly my paranoia of not doing it right, not getting everything tightened up. Like I said, each time i have checked, they are closer to spec each time. Last check, I only monkeyed with a couple, all others were fine. The shop I used is highly respected out here, so I HOPE they did me right.
Everything is stock spec. Seats were changed, although i am not sure what brand the shop used.
I do find myself getting faster and better at in-car adjustments, so I kinda think my perceptions and measuring/adjusting techniques have a good deal to do with it.
