jimkelly
May 24 2010, 10:27 AM
i will stick with the 65mm studs all around and porsche nuts with R14 ball seats.
i'd say 65mm up front and 80mm for rear is better.
i have a torque wrench on the way to my house from sears : ) - for the nuts, not the studs.
yeahmag
May 24 2010, 10:56 AM
I'm using the same studs with a bit of blue loctite and just barely snugged them in to the rotor. So far so good.
DanT
May 24 2010, 11:26 AM
I will probably go with the 80mm studs since I will be running either 7 or 10mm spacers front and rear with my 4 bolt Fuchs and 205x50x15 tires.
Sleepin
May 24 2010, 01:56 PM
DAPO's around the world agree: Screw in studs are the way to go!If you do it, please do it right.
Not like this:
DanT
May 24 2010, 04:54 PM
that is a step down stud.....
absolutely nothing wrong with screw in studs if done correctly with good quality parts
