Hi!
Why are you not using powdercoating ?
In that colour it should not cost more than 10 Euro.( 12 dollar )
I painted mine in semigloss black looks great.
Just sandblasted it before and when it was painted
I used tanksealer looks great.
Niklas
Niklas,
If you'll provide a pic of your tank, I'll explain why it is not the "correct" finish.
However, I will say this....the Factory did not use powdercoating, hence the finish is incorrect. Powdercoating did not surface until the early '80's, and it was used on office equipment. The finish was fine for filing cabinets, but the "nubby" finish has no place on a 914. Oh, I almost failed to mention this - 914 components were paint sprayed. And this finish is entirely different. You know, original in appearance.
Some will say that I am extreme in maintaining originality. Probably so, but original is original. Now I know that once a finish is re-finished it's no longer original. But, if you can make people wonder if the finish is original or not....you've won your point.
So, send us a pic of your powdercoated tank.
Pat
