Wayne
Feb 7 2017, 09:46 AM
PM sent
aggiezig
Feb 7 2017, 11:52 PM
PM Sent.
sawdust
Feb 15 2017, 07:42 PM
QUOTE(Rotary'14 @ Aug 15 2010, 11:49 PM)
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO.
Engine Compartment $22 each + $10 shipping
Engine Compartment set (2 lines) $40 + $10 shipping
Tunnel fuel line each $38 + $14 shipping
Tunnel fuel line (set of 2)$70 + $16 shipping
complete your installation with the following,,,
Fuel tank fuel sock $10
Fuel tank sealing ring $.50 each
Firewall grommets $2.00 each
Engine shelf grommets $4.00 each
FI hose clamps $2.00 each or $1.75 each(if you order more than 10)
Shipping included if you buy a set of lines.
Can these be installed with the engine in?
Thanks for looking!
Rotary'14
Mar 1 2017, 05:15 PM
QUOTE(sawdust @ Feb 15 2017, 05:42 PM)
Thanks for looking!
Yes the tunnel lines can be installed with the engine in. The higher up you get the car,, the easier it will be. And you really should remove the fuel tank to make the job easier.
-Robert
arvcube
Apr 5 2017, 08:21 PM
Just installed my set. Easy install. Jacked up the rear on stands, didn't have to remove anything. Fished it through. The ends snapped right into the existing clips. Thanks for a great product Robert!
emmy914
Apr 22 2017, 10:42 AM
QUOTE(Rotary'14 @ Aug 16 2010, 01:49 AM)
I am in need of replacing the fuel lines from the tank back to the motor and engine compartment lines- all.
Also, all of the lines on the fuel injection system. I have no idea of the total number of clamps need. I would want a few extra. Do you sell the injection line as well ???
1975 2.0. The long term project is to up hp by a modification of 2.0 or swap for more cylinders - V8. If that is a larger size line I am going to do that now.
I want everything to do it right....Fuel tank fuel sock, Fuel tank sealing ring,
Firewall grommets - how many 2 ???
Engine shelf grommets - how many ???
I can be reached at 419 276 2299.
Thank you and God Bless
Jim
Thanks for looking!
seanpaulmc
Apr 23 2017, 06:42 PM
PM sent
sholman5
Apr 30 2017, 05:15 PM
QUOTE(seanpaulmc @ Apr 23 2017, 08:42 PM)
PM sent
PM sent
sholman5
May 13 2017, 06:07 AM
Received mine yesterday. Great workmanship. Install was a breeze. Engine was out. Took me about 20 min to install including removal of old lines. If you don't have these lines and have the ability to replace them. DO IT.
Wyvern
Dec 16 2017, 05:43 PM
PM sent to OP.
Are you still putting the kit together ?
slyder
Jan 11 2018, 07:48 PM
PM sent
Rotary'14
Jun 26 2018, 03:57 PM
Even though I am not actively posting,, I am still making these and responding to PMs.
Friendly bump.
VintageExcellence
Aug 21 2018, 02:07 PM
Robert, sent you a message, need a pair of lines
rhodyguy
Aug 21 2018, 03:22 PM
His email feature is active in his profile.
mb911
Jan 2 2019, 02:38 PM
Pm'd a while ago. No response? Not sure if this service is still offered?
JmuRiz
Jan 3 2019, 01:22 PM
Yes it is, I got a set a couple weeks ago.
Maybe a full inbox?
Give him another try and he should respond.
rallysport70
Feb 9 2019, 04:36 PM
PM sent
flmont
Jun 15 2019, 03:20 PM
Do you make custom lines,I would like the ends bent in different directions..?? Thanks frank
Rotary'14
Jul 9 2019, 05:39 PM
Bump to let everybody know I'm still around.......
PMs work much better than email for me because I lost access to my old email account.
and not sure how to change it,,,,,
ndfrigi
Jul 9 2019, 05:47 PM
QUOTE(Rotary'14 @ Jul 9 2019, 04:39 PM)
Robert,
to change email settings:
Go to Control Panel then
Go to Option then select Change Email.
Anyway, I will be ordering tunnel fuel lines soon again.
chipndayle
Jul 12 2019, 02:17 PM
QUOTE(Rotary'14 @ Jul 9 2019, 07:39 PM)
Hi Robert -- I want to buy a set of the SS lines. I sent you both an email and a PM, but have not heard anything.
If someone else knows Robert and could call or contact him, I'd appreciate it.
All the Best, Chip
914werke
Nov 8 2021, 08:46 AM
I also recently reached out to Robert, similar result anyone local to him know of his status?
76-914
Nov 8 2021, 09:17 AM
Don't forget that Chris Foley at Tangerine racing sells those lines also.
rhodyguy
Nov 8 2021, 11:08 AM
Are guys using the email or pm options to contact Robert?
Nov 8 2021, 11:34 AM
QUOTE(76-914 @ Nov 8 2021, 10:17 AM)
Yes. I buy from him and have always received great service.
Rotary'14
Jun 3 2022, 02:18 PM
PM thru the world works well for me
