Krieger
Dec 9 2011, 06:57 PM
Here is one of my rebuilt Ferrari rear calipers. All I need for the rears are pads!
Krieger
Dec 9 2011, 07:02 PM
Front sway bar and heavy A calipers. When I learn how to drive I will replace the A's with something better. I need to run brake lines and add master cylinder.
Krieger
Dec 9 2011, 07:08 PM
Something simple, cheap, light and fun. If you were in a US made jet and wanted to get out of a plane in a hurry you'd reach up above your head and grab yellow/black cable like this to punch out. Home Depot special $9. Eject label from office label maker free. Effect...priceless
Krieger
Dec 9 2011, 07:13 PM
I didn't want to do this project. I'm getting tired of projects and I just want to drive this freakin car. Oh well, it was pretty easy with my drill and jig saw. I also had some aluminum left over from making the dash. I forget how cool it is to work with aluminum. I welded nuts on the engine compartment side of the firewall to hold it down.
Krieger
Dec 9 2011, 07:16 PM
One of my "buddies" conviced me I needed to do the access panel. Just to the left you can see the bolt heads I tacked in place to mount the coil in the engine compartment.
Krieger
Dec 9 2011, 07:22 PM
Here is the engine compartment with my new connector eliminating the use of the relay board. I shortened a good amount of the original harness to put the plug in this location. The voltage reg was the only "compromise" if you want to call it that. I have the bracket for the engine mount temporarily mounted to help me with figuring out the oil line routing. My coil is wired in to the body harness and so is the distributor pick up lead.
Krieger
Dec 9 2011, 07:28 PM
Oil line routing in front trunk. The lines are going in the passenger long, then into the passenger compartment. Through the front bulkhead to the cooler.
Krieger
Dec 9 2011, 07:32 PM
Passenger side. Hole saws courtesy my pal Marty.
Krieger
Dec 9 2011, 07:37 PM
Windshield from that same doner car at pick n pull. It has a couple of small scratches otherwise awesome shape. I got it out, home and installed without breaking it! Rubber seal/butyl from Mikey. 3m black primer.
Krieger
Dec 9 2011, 07:46 PM
I liked the look of the original chrome wiper harware.
Krieger
Dec 9 2011, 07:50 PM
Almost forgot. The MSD 6AL box is wired into the harness along with the tach adapter. All I need is a couple of ends installed.
Jeffs9146
Dec 9 2011, 11:33 PM
What year 3.0L is it? I didn't need a tach adapter for my MSD6AL on a 3.0L! My motor is an '83sc with a '79 tach!
I didn't think the 4 cylinder tach will work even with the adaptor...maybe I am wrong?
EdwardBlume
Dec 10 2011, 06:45 AM
QUOTE(Krieger @ Dec 9 2011, 05:46 PM)
What you see of the wiper system is all there is...
Vent delete looks cool! How did the dash install go?
Krieger
Dec 10 2011, 09:05 AM
The engine is from a 78. The tach is from an unknown 911. If I need to I could always cut that tach adapter out. I needed a tach adapter for my 4 cylinder 75 with MSD6 box.
Rob the dash was easy to install. I used the two bolt holes on the top center. Then large (maybe 1/8") sheet metal screws on each side into the cage
Krieger
Dec 24 2011, 03:26 PM
Here is a close up of the paint, er glass beaded aluminum finish! Well the wiper nuts are glass beaded aluminum!
Randal
Dec 24 2011, 05:13 PM
QUOTE(Krieger @ Dec 24 2011, 01:26 PM)
I really like the paint. Super cool.
Randal
Dec 24 2011, 05:16 PM
QUOTE(Krieger @ Sep 26 2010, 08:49 AM)
I have some more time to post pictures correctly. The car was painted last month a matte metalic silver. This paint is a polyurethane and looks awsome in the sun. In the garage it looks a little dull. Basically it looks like glass beaded aluminum! The paint is from TCP Global in San Diego. Hot Rod Flats is the color line.
Did you paint it yourself?
Krieger
Dec 24 2011, 06:03 PM
I had someone spray it in my garage. I'm good with a spray can though!
Krieger
Apr 20 2012, 11:18 PM
Got my oil lines and fuel system done! Mazda RX-7 cooler and Holley red fuel pump. Stainless fuel lines courtesy of Tangerine Racing. I have both installed even though I only am using one now.
Krieger
Apr 20 2012, 11:21 PM
I ran the lines in the long and wrapped them with a heat insulating material. A little bit of work with a hole saw and grinder.
Krieger
Apr 20 2012, 11:24 PM
The left engine compartment view. Yes the line is run over the stock 6 engine mount, then fastened to the brake dampner. GT style engine mount bracing encouraged by Mr. Eric Shea.
Krieger
Apr 20 2012, 11:31 PM
Here is the right side detail. with my home grown battery tray....wait till you see my "hot rod' style battery hold down. All the ignition components are wired into the body harness.
Krieger
Apr 22 2012, 08:06 PM
A better view of oil thermostat and line routing.
Krieger
Jun 24 2012, 12:27 PM
Carbs done! I did the float bowel mod to keep the mains fed in corners.
Krieger
Jun 24 2012, 12:28 PM
Engine/trans going in!
Krieger
Jun 24 2012, 12:30 PM
Bingo!!
Note the fancy puke bottle set up pirated from one of the guys here.
Krieger
Jun 24 2012, 12:52 PM
MSDS 1 1/2" headers ceramic coated. I am using the stock SC muffler for now. Bungs added for an oxygen sensor in both.
Krieger
Jun 24 2012, 12:57 PM
I came up with a creative solution for an oil tank drain plug. I ordered the factory oil lines from the the tank to the cooler. It came with a union. I had a face machined then drilled and tapped it for a drain plug. I drilled the plug so I could safety wire it. This is one of many parts my pal Dean machined for me.
Krieger
Jun 24 2012, 01:01 PM
Installed. I welded in a bracket to support the set up. One large adele clamp to hold it.
Krieger
Jun 24 2012, 01:05 PM
Sir Andy style axles. I needed loger CV bolts than the 45mm units that came with the 944 cvs. These are 55mm and need to be trimmed so they didn't interfere with the trailing arm. Not an issue on the trans flange side. I couldn't find appropriate 50mm bolts. Also note Sir Andy inspired picture quality.
Krieger
Jun 24 2012, 01:08 PM
All trim!
Phil Plummer
Jul 21 2012, 05:03 PM
QUOTE(Jeffs9146 @ Dec 9 2011, 09:33 PM)
Hi iam doing a 914 with a 3.0 porsche 911 sc from an 81 and was wondering if I cant install and run car without adapting any wiring or otherwise computer stuff that was in the '81 911 sc
I upgraded starter and oil tank and flywheel, bearing and clutch (from Kennedy engineered prouducts)and headers and throttle cable
Do I have upgrade anything else? and what about a 911 tach I'm putting in? please help-Phil
Krieger
Feb 2 2013, 10:49 AM
I need to do some ignition, carb sorting and alignment/balance but she is running! I decided to go with fiberglass bumpers.
Krieger
Feb 2 2013, 10:52 AM
The rims on it now are my street wheels.
Krieger
Feb 2 2013, 10:54 AM
I had my OMP seats covered in army style heavy OD canvas.
Krieger
Feb 2 2013, 10:57 AM
jeff
Feb 2 2013, 02:34 PM
I love it!
Lennies914
Feb 3 2013, 10:43 AM
Looking awesome Andy!
Phil Plummer
Mar 6 2013, 08:46 PM
QUOTE(Krieger @ Feb 2 2013, 09:57 AM)
Hi I am building a 914/6 with a 3.0 in it from a 81 911 sc and All is ready to go just NO Spark ...Cd box humms...amd I stayed with the original injection system..coil etc all good...Please help or direct me if you can -Regards Phil
Krieger
Mar 7 2013, 06:38 PM
Hey Phil. I am totally unfamiliar with the factory ignition. I am using an MSD ignition system. Post something in the garage here and maybe somebody like Cap n Crusty will know. Do a search here, or maybe on Pelican Parts site in the in the 911 BBS where the taildraggers hang out.
Lennies914
Mar 7 2013, 08:59 PM
QUOTE(Phil Plummer @ Mar 6 2013, 06:46 PM)
I assisted Jeffs9146 with his 3.0 sc conversion and we had the same trouble. It was our solution to replace the factory ignition with the MSD 6L setup.
Phil Plummer
Apr 2 2013, 06:29 AM
QUOTE(Krieger @ Sep 26 2010, 09:11 AM)
Another rear trunk done!
Hi I have put a 3.0 from a 911 sc into my teener
It sounds awsome but will not idle on its own I have to feed gas through spray bottle
-Wur (Warm up reg is fine I think) It has power and bimetal strip gets hot and it is clean as a whistle
-cold start vavle is fine
- it all appars to be wired right and I am at wits end please help if you can
Krieger
Apr 2 2013, 01:46 PM
My car has carburetors. If you look at the pics you'd see that. I don't know but I think a warm up regulator gets you air not fuel. You should post a new thread in the garage asking for help.
Mark Henry
Jul 16 2013, 12:30 PM
Cool build
MATTYLITE
Jul 16 2013, 01:16 PM
The headlights look great! Is that just flat lexan over the light buckets?
Any closer images of this?
Krieger
Jul 16 2013, 07:55 PM
Thanks Mark! The covers are just flat Lexan. I had the car Aligned and corner balanced and with a half a tank of gas she weighs 2050#!
Chris Pincetich
Jul 17 2013, 11:39 AM
SWEET
3d914
Dec 27 2013, 07:31 PM
Looking awesome, Andy. now lets hear that thing growl!
Krieger
Jan 19 2014, 02:31 PM
For fun I had some placards made at Aircraft Engravers. $8 shipped!
3d914
Mar 28 2014, 12:43 PM
Nice touch! I hope those guns are rear-mounted! My last 914 seemed to attract every manner of road-going carnivore sniffing its tail.
