QUOTE(Eric_Shea @ Nov 13 2010, 09:59 PM)
The nice thing is that a 914 chassis is a great starting point for whatever moves you.
OK... I'll bite and play Mr. Contrair in a pool full of 3.0+ guys
I've seen quite a few 914 chassis literally torn apart. Granted most were rode hard and put away wet but the chassis has it's limitations. So, while it can be a great "starting point" it should be strengthened and modified if you plan on utilizing all that torque.
To the original question; drivability? How could you go wrong with (almost) any of them. Quite simply, the more torque, the better it is in the drivability department. That's said, it's hard to beat a bigger motor.
I just don't think a 914 is very well suited for anything over a 2.7 (long term) Matt (hasaramat) was over today and we were discussing just that. For a driver, a 2.7 with E-Cams would be a dream to drive.
So... I'd say a street driven car with any motor you desire would be great. The 3.2's or the 3.6 would be tops on my list becaue of the "turn the key... go pick-up a gallon of milk" usability of the later fuel injection. Just keep in mind, if you get crazy with the right foot, all that torque will eventually cause some rips and tears unless you're fortified (and even then, it's questionable whether you can tame the beast).
Bottom line for me; I doubt if "I'll" ever put anything bigger than a 2.7 in a teener but... I could very well eat those words with a big happy smile on my face some day.
perhaps "mr contrair"
could explain the economic feasability of a build up of a 2.7 on a tired ole mag case that has seen more milage/streses as opposed to a tough alum block...
the job of supporting a chassis/rear suspension is really not that much work when a motor is out...be it on a four w big slicks, or a big six
but i do agree that even a early 3.0 has a lot of torque, and i cant see myself needing any more, torque helps streetablility, as opposed to a peaky small bore screamer. but the simplicity of the install of 3.2 with motronics, would be my pick for an install now over a 3.0 w cis, unless going with carbs (the cis clearance being the issue)
but then there are divlar studs......
